Περσεας
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Rogue Audio Perseus Tube Preamplifier
Specifications:
● Mu-follower Tube Design
● MFR: 5 Hz - 50 kHz ± 1 dB
● THD: 0.1%
● Four Inputs, Three Outputs
(RCA)
● Output Impedance: 450 Ohms
● Maximum Output Voltage: 20
Volts RMS
● Dimensions: 4.5" H x 18" W x
14.5" D
● Weight: 22 Pounds
● MSRP: $1,795 USA
"...Lately, I've enjoyed reviewing the convenience of integrated amplifiers, and with so many exceptional pieces, I've shunned the need for a separate preamplifier. Oh, what I was missing! The phono stage, especially, can certainly make the difference on a modest turntable, elevating it to "much better".
Those who simply cannot find space for a separate two-channel system can add the benefits from this analog source easily with the HT Bypass feature. Although I spent most of my time with the Perseus in a separate room with a two-channel system, placing it in my solid-state surround sound greatly improved the system with more character, dimension, texture, and an overall timbral balance. It's literally painful to remove it from that system. If your motive is the same as mine, you want the pure enjoyment of music.
You've heard this before about components and you'll hear it again - the Rogue Audio Perseus is a bargain for a preamplifier of this caliber.
Ελληνικη αντιπροσωπεια
http://www.aphroditesvision.com/
Ημίθεος
Μιας και εδώ δεν είναι USA, μήπως είναι δυνατό να μάθουμε και την τιμή του σε ψωροκωσταινέικα ευρά; (Μιας και μνημονεύεται ότι ο κατασκευαστής αντιπροσωπεύεται στην Ελλάδα, δηλαδής)...
TehLooney
