Πυκνωτες Jantzen Audio Z ALUMEN 6,80 ΜF
Diylover
Φτιάχτε ενεργά!!!
Πωλουνται στη συσκευασια τους, ολοκαινουργοι, λογο αλλαγης κατευθηνσης απο παθητικα ηχεια σε ενεργα, 2 πυκνωτες υψηλης ακριβειας:
JANTZEN 6,80 ΜF Z ALUMEN VDC 100 3%
http://loudspeakerfreaks.com/Product.asp?mfr=Jantzen Audio&part=001-7050&Product_ID=13190
GENERAL DESCRIPTION
The Alumen Z-Cap is the newest addition to our line of high-end audio capacitors. The Alumen Z-Cap was especially designed for the tweeter and mid-section of crossovers for passive hi-fi speakers.
The improved transparency performance of this new cap is on the same high level as our SilverGold Z-Cap, but with a slightly softer tonal presence and less brightness / sheene / glare in comparison.
The Alumen Z-Cap will offer a more “neutral” presentation in the overall sound in certain crossover designs, and by “neutral” we refer to the focus will be shifted from what can be a somewhat overemphasized brightness from a Super PP cap, being replaced with a more even balance between the depth of the midrange and the presence of the tweeter.
Alumen Z-Caps are not suiteable for use in amplifiers, for this application we recommend our Superior, Silver or SilverGold Z-Caps.
PRODUCT SPECIFICATIONS
Value µF 6.80
Tolerance +/- % 3
VDC 100
Diameter mm 25
Length mm 87
Type MKP capacitor
Product quality High grade
Η αφροκρεμα των προσιτων πυκνωτων με εξαιρετικα reviews για κατασκευη crossover. Η τιμη ειναι καλη στα 60e εκαστος. Κατα προτίμηση απο Αθηνα.
Stearsa
