Πωλούνται ηχεία KEF 1005.2
Πωλούνται ηχεία 5.1 Ασημί KEF 1005.2 σε άριστη κατάσταση.
Δορυφόροι
Model HTS1001.2 Satellite / HTC1001.2 Centre
Type Two-way closed box
LF Drive Unit 75mm (3in.) Uni-Q®, 15mm (0.6in.) aluminium HF
Crossover Frequency 3kHz
Frequency range (± 3 dB) 120Hz - 22kHz
Amplifier Requirement 10 - 100Watts
Sensitivity (2.83 V / 1 m) 86dB
Maximum Output 104dB SPL @ 1m
Impedance 8½
Net Weight 0.7kg (1.5lbs)
Dimensions (H x W x D) Satellite 165 x 110 x 78 mm (6.5 x 4.4 x 3.0 in.)
Centre 107 x 181 x 78 mm (4.2 x 7.1 x 3.1 in.)
Το Sub είναι το KEF PSW1000.2 100wrms
Design Bass reflex, downward firing
Drive unit 200 mm (8")
Frequency response at 15°
horizontally off axis ±3 dB 38 Hz - 180 Hz
Crossover frequency variable
Amplifiers 100 W built in
Maximum output 106 dB
Magnetic shielding Yes
Weight 13.5 kg (29.7 lbs)
Dimensions
(H x W x D) 360 x 320 x 320 mm
14.2 x 12.6 x 12.6 in.
TIMH 350Ε
Απάντηση: Πωλούνται ηχεία KEF 1005.2
Mpermplis
