Ραδιοενισχυτής SONY STR-DB840 RECEIVER
Ραδιοενισχυτής SONY STR-DB840 RECEIVER, περίπου 4 ετών, σε εξαιρετική κατάσταση, και εξαιρετικό ήχο. Ειχε τις καλύτερες αξιολογήσεις απο΄τα ελληνικά περιοδικά ήχου, και εάν θυμάμαι καλά ο "Ηχος" τον είχε βραβευσει ως ο καλύτερος ραδιοενισχυτής στην κατηγορία του.
Τεχνικά χαρακτηριστικά:
* Dolby Digital, DTS, and Pro Logic decoding
* 100 watts x 5 into 8 ohms (20-20,000 Hz) at 0.09% THD
* multibrand, 1-way LCD remote with macro capability
* 4 digital inputs (3 optical, 1 coaxial)
* optical digital output
* 5.1-channel input
* stereo "analog direct" mode
* 3 audio, 5 A/V (including 4 S-video and 1 front-panel) inputs
* preamp outputs for all channels
* binding posts for all speakers
* aluminum front panel
* large filter capacitors, power supply, and output transistors
* separate processors for Dolby Digital/DTS (24-bit) & Digital Cinema Sound (32-bit)
* 30 AM/FM presets
* Control A1ii & S
Και να τι λένε άλλοι για τον SONY STR-DB840 ραδιοενισχυτή (συγνώμη είναι στα αγγλικά):
"DB Series" receivers borrow elements of construction and design from Sony's high-end "ES" line; you enjoy near-ES sound quality while saving a few hundred bucks! Last year's DBs were among our best-selling receivers ever. This year's DBs push the performance even further.
Flip down the 'DB840's front-panel door to reveal a convenient set of A/V inputs plus numerous control buttons; flip the door up for elegant looks in your home theater. Its back panel treats you to a smorgasbord of ins and outs (see "Key Features" below) for versatility now and expandability down the road. The 'DB840 is also a DSP dream come true, with separate processors for Sony's exclusive Digital Cinema Sound™ (32-bit) and for Dolby® Digital, DTS, and Pro Logic™ decoding (24-bit).
Read More
You'll be blown away by DB's top-notch construction and amp quality. Beefy output transistors (35% larger than last year's!) are mounted in-line on a cast aluminum heat sink for rock-steady multichannel sound. Oversized "guts," an anti-resonant aluminum front panel, and 100 full-bandwidth-rated watts x 5 channels make for precise, powerful reproduction of Dolby Digital's explosive dynamic peaks! And whether you're feeding digital audio to its 96kHz/24-bit D/A converters, or bypassing all DSP via "analog direct" (great for high-resolution stereo sources like SACD!), you'll experience nothing short of amazing sound.
Τιμή : 190 ευρώ
Επικοινωνία με πμ, η email στο [email protected], η τηλέφωνο στο 6947998052.
Συνεχίζει να ειναι διαθέσιμος για πώληση ..... ειναι κρίμα ένας τόσο καλός ραδιοενισχυτής να "κάθεται"
kosmidhsn
