Ρολόι G shock M100B-1AER solar
hamurabi
Καλησπέρα παιδιά.πωλειται ελαφρώς μεταχειρησμενο,πανέμορφο με το κουτάκι του μαζι, και είναι solar,η μπαταρία δε χρειάζεται ΠΟΤΕ αλλαγή αφού φορτιζει Άπτον ήλιο.
60 ευρώ απο 110 που κάνει καινούργιο.
https://www.skroutz.gr/s/447063/Casio-Mens-G-Shock-Chrono-AWG-M100B-1AER.html
hamurabi
Σε υπέρ άριστη κατάσταση, αγορασμένο πριν λίγους μήνες,είναι solar δηλαδή δεν αλλάζεις μπαταρία ΠΟΤΕ , πανέμορφο και είναι λίγο πιο μικρό απτά κλασσικά gshock .
Aγηρασμένο 120ευρω το δίνω ένα 60αρι να φύγει .
Πρέπει να εχω και το κουτάκι του.
Technical Specifications
  • Full-Auto-LED light
    A twist of the wrist in weak light conditions automatically lights up the display backlight.
  • Shock-resistant
    Shock-resistant construction protects against impact and vibration.
  • Solar Power
    A solar cell provides power for operation.
  • Radio signal reception (EU, USA, Japan, China)
    Whether in Europe, North America and Japan or in the outer reaches of Canada, Central America and China - once the watch has been set to the local time, it receives the relevant signal and shows the correct time wherever you are. In many countries, it also sets itself automatically to summer and winter time.
  • World time function
    Displays the current time in major cities and specific areas around the world.
  • Stopwatch function - 1/100 sec. - 1 hour
    Elapsed time, split time and final time are measured with 1/100-sec accuracy. The watch can measure times of up to 1 hour.
  • Timer - 1/1 sec. - 100 min.
    The countdown timer emits a signal after a preset period of time has elapsed. The watch has a maximum timing capacity of 100 minutes and can be set in second-long cycles.
  • 5 daily alarms
    The daily alarm reminds you about recurring events with an acoustic signal at the time you have set. This model has 5 independent alarms for flexible reminders of important appointments.
  • Hand Moving Function
    With a push of a button, hands are moving and permit a free visibility of functions like stopwatch or date.
  • Button tones on/off
    The button tones for using the mode button can be turned off. This means that the watch no longer beeps when switching from one function to another. Preset alarm or countdown timers remain active when the button tones are deactivated.
  • Automatic calendar with Date, Day and Month
    Once set, the automatic calendar always displays the correct date.
  • 12/24-hour timekeeping
    Times can be displayed in either a 12-hour or 24-hour format.
  • Mineral glass
    The tough mineral glass resists scratching.
  • Resin case
  • Resin band
    Synthetic resin is the ideal material for wrist straps thanks to its extremely durable and flexible properties.
  • Buckle
  • Battery level indicator
    An indicator shows the current battery level.
  • Water resistance classification (20 bar)
    Perfect for free diving without scuba gear: the watch is water resistant up to 20 bar according to ISO 22810.
  • Dimensions (H x W x D)
    52,0mm x 46,4mm x 14,9mm
  • Weight
    approx. 56,40 g
    Availability of models and/or lineups may differ depending on the country or region.
    Technical amendments and errors excepted. The sizes in figures do not correspond to the original sizes.
    The colours may differ slightly from the original.
gagakostas
