Σε τι μοιάζει;;;; ;-)
Για να κάνουμε ένα γρήγορ quiz...
Σαν τι σας μοιάζει ο παρακάτω δέκτης;;;; Μήπως σαν το μεγάλο του αδερφό με όλα τα νέα καλούδια (HD dvb-s2 tuner,pvr,lan,linux κλπ) αλλά με ένα ....μηδενικό λιγότερο στο όνομα και υποπολαπλάσια τιμή; ;-)
Απάντηση: Σε τι μοιάζει;;;; ;-)
έχουμε κάποια επιπλέον πληροφορία , όχι ότι θα βγει προσεχώς !
Ακριβώς... ο νέος DM800 HD PVR ....
Χαρακτηριστικά (μετάφραση από...κινέζικα...)
- The receiver has the sizes similar DM600-S PVR
- On the forward panel opens (as at DM7020 or DM7020) under which to be one card.
- The forward panel as is equipped high-contrast LCD by the display (a small variant of the display similar DM7025+). The display has blue color.
- The receiver allows to accept Mpeg-4 AVC H.264
- The receiver has built in HDD for record including programs under Full HD the sanction. ON a receiver (Enigma II - on architecture very much reminds ON from DM7025 +) allows to establish HDD in capacity up to 500s. Enigma II has the Russian version of the menu, correctly displays names of channels in Russian and work EPG.
- The receiver has one replaceable tuner DVB-S2, which can be easily replaced (at all not having special skills) on DVB-C or DVB-T.
- In the complete set of receiver DM800 HD PVR the big board similar from DM7025 + is enclosed
- The receiver is equipped external and a current
Now we shall paint sockets:
On the back panel are present: RS232, DVI, 2xUSB2.0, LAN-Ethernet 10/100, Scart, optical port of digital audio S/PDIF and the plug for connection +12B from external .
For reception of output HDMI complete with a receiver there is cable DVI-HDMI (HDMI version 1.3) long 1,8 meters.
We shall soon place a photo of a receiver and its description on our site in the form of separate clause.
The first deliveries of receivers DM800 HD PVR are planned on 15-25 march 2008. Watch news...
Το υποπολλαπλασια τιμη πως ακριβως οριζεται ας πουμε? Εχουμε καποιες πληροφοριες?
ΟΛΕ ΟΛΕ ΟΛΕ!!!
αντε γιατί ερχεται και καυτό καλοκαίρι HD!!!!
i kathimerinotita se HD ine pio prositi para na doume mono tous olimpiakous agones se HD.
kafto tha ine etsi kai alios mias kai ellada menume !!
Για παμε για παμε!!!!
Επρεπε να παρω εγω ο γκαντεμης τον 600 για να βγαλουν τον HD :happy_9:
Τιμουλα θα μας πει κανεις ??
o περιμενων νικά??? εχω φάει τα δάχτυλα μου και την τσέπη μου να μην αγοράσω ουτε skystar2HD ήθελα η πρώτη μου HD SAT λύση να είναι dream...!!!! τι usrname συντηρούμε τόσα χρόνια!!!
Gianni i singrisi pou kanis anamesa skystarhd kai dream ine lathos ,i diafora mono stin timi ine terastia , i ikona pou vgazi i skystarhd eksartate apo ton xristi pia codecs xrisimiopi .
skystarHD=110EURO kai meso hdmi dini mia ekpliktiki ikona se tileorasi !!
dm8000=800 euro to ligotero
dm800=500 euro pano kato apo ti exo akousi makari na vgi pio ftino.
δεν τα συγκρίνω προς θεού... απλά ανέφερα ότι όσο και να με γαργάλαγε τόσο καιρό η HD DVB-S δεν ενέδωσα όυτε κάν σε αγορά καμμιάς φθηνής SS2HD...!!!
Ας ελπίσουμε όμως οτι τα dream 800 ή 8000 θα είναι στα 350-450 και 600-700 ευρώ αντίστοιχα φθηνότερα δεν τα κόβω...
Πωωωω τι μου κανατε τωρα. Απο Δευτερα κανονιζα αγορα του 600 στα 270 ευρω. Τι να κανω, να περιμενω? Παντως χλωμο το κοβω να παιξει η τιμη κατω απο 400 αργυρια.
papaevagelouv
