ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Προσεξτε τι προσφερει:
* 8 channels
* 8 configurable inputs
* 3 independent zones
* Integrated 7-channel amplifier with thermal/DC protection and toroidal power transformer
* AM/FM stereo radio tuner
* Phono input with 2-channel analogue bypass path
* Up to two 5.1-channel analogue audio input connections
* Analogue bypass option for 5.1 analogue and stereo audio inputs
* Auto switching between digital and analogue audio inputs
* Headphone output with LOGIC7 processing
* Two 32-bit DSP engines for custom processing
* Separate DSP engine for decoding compressed audio sources
* 4 coaxial and 4 S/PDIF optical (Toslink) digital audio inputs
* 1 coaxial and 1 S/PDIF optical (Toslink) digital audio output connectors
* 24-bit/192 kHz D/A converters for all audio channels
* 2 sets of analogue A/V Zone 2 outputs; 1 fixed, 1 variable
* 1 set of analogue audio Zone 3 outputs, variable level
* Broadcast-quality video switching
* Video up conversion from S-video/composite input to component video output
* 3 component video inputs with full HDTV compatibility
* 5 composite video inputs
* 5 S-video inputs
* 1 component video output
* 4 S-video output connectors
* 5 composite video output connectors
* LOGIC7 decoding
* Dolby Digital Surround EX, Dolby Pro Logic II, and Dolby Pro Logic decoding
* DTS 96/24, DTS-ES (discrete and matrix), and DTS neo:6 decoding
* THX Ultra2 and THX Surround EX decoding
* THX Ultra2 certification
* Flash memory software upgrade capabilities
* 2 internal expansion slots for possible future developments
* RS-232 control
* Rear-panel IR input connector
* 2 trigger output connectors
* Optional 19-inch rack-mount kit
* IR pre-programmed/learning remote control with LCD display
Λοιπον παμε για Lexicon?
