Σχέση μεταξύ τιμής και ποιότητας στα ακουστικά...
...δεν υπάρχει. :)
Μετρήθηκαν 283 ακουστικά με τιμές απο $4 έως $5000+.
http://www.audioholics.com/loudspeaker-design/price-sound-quality-headphones
http://asa.scitation.org/doi/full/10.1121/1.4984044
Conclusions
Based on the evaluation of the mean, variance, PCA, and mean square error with respect to a target function, no correlation could be observed between the measured magnitude response and retail price of headphones. However, the variance in low-frequency response seems to decrease with increasing price, indicating an improved bass response measurement consistency across headphones in the higher price range. It is however unclear whether this improved consistency with a higher retail price is the result of better headphones or better repeatability of measurements with more expensive models. Nevertheless, assuming that the perceived audio quality is largely determined by the spectral magnitude response of headphones, there are plenty of relatively cheap models that match the assumed target function, as well as very expensive ones that deviate significantly from an assumed ideal response.
On average, IE headphone measurements demonstrate slightly more bass than CA and SA headphones. The difference amounts to approximately 4 dB at 100 Hz. This finding is in line with subjective preference ratings reported by Olive et al. (2016). The observed higher bass response could be resulting from a greater seal between headphones and artificial ear compared to the seal for human ears (ITU-T P.380, 2003).
CA and IE headphones have a response that (on average) more closely mimics the target curve proposed by Olive and Welti (2015) than SA headphones.
The target function suggested by Olive and Welti (2015) is fairly similar to the average headphone response found in this study, with the exception of a deviation of up to about 5 dB for frequencies between 50 Hz and 2 kHz.
PCA can account for 90% of the variance across all measured headphones with six eigenvectors. The first eigenvector is similar to published target responses, while the second eigenvector represents a global spectral tilt.
TGD
Thread Gravedigger
Ε, μόνο εγώ βρίσκω λίγο τραβηγμένο τον συλλογισμό του Audioholics;
frequency response was by far the greatest factor in headphone sound quality
frequency response had a nearly insignificant correlation to the cost
No Correlation Between Price and Sound Quality in Headphones
Μήπως τα πιο καλά ακουστικά είναι αυτά που πλησιάζουν την target curve; Βλέποντας τις μετρήσεις των ακουστικών που θεωρούνται γενικά κορυφαία, μάλλον έτσι είναι.
Μήπως τα φτηνά ακουστικά έχουν περισσότερο μπάσο γιατί απευθύνονται σε συγκεκριμένη αγορά;
Μήπως το ότι δεν έχουμε όλοι ίδια αυτιά σημαίνει ότι κάθε ακουστικό θα ακούγεται διαφορετικά στο αυτί καθενός; Κι εδώ δεν μπορούμε να κάνουμε room correction!
Α, και κάτι ακόμα. Αφού το target function των Oliver & Welti χρειάστηκε να κατέβει 6,5 db για να συγκριθεί με την μέση τιμή των ακουστικών, μήπως είναι λογικό τα ακουστικά να έχουν μεγαλύτερη έμφαση στις μεσαίες συχνότητες ώστε να ακολουθούν κατά το δυνατόν την σωστή απόκριση σε χαμηλότερες εντάσεις;
xfader
Το VST plugin Morphit που αναφέρεται στο 2ο link κάνει πολύ καλή δουλειά. Ανάλογα plugins υπάρχουν και για τα μικρόφωνα (π.χ. Antares Mic Mod EFX ). Τα χρησιμοποιούσαμε σε ηχογραφήσεις καλλιτεχνών, κυρίως για να δώσουμε μία vintage αίσθηση στα φωνητικά.
Manosahead
