Mr Spock
demokratischer - sektor
Πρόκειται για τα πικάπ της Πολωνική J. Sikora, ενός κατασκευαστή που υπάρχει στο βινυλιακό χώρο από το 2007. Τα πικάπ όπως και οι βραχίονές της είναι υπερκατασκευές. Υπάρχουν τρία μοντέλα, τα Ιnitial, Standard και Reference.
http://www.hxoseikona.gr/nea/7231-j-sikora.html
Total weight [kg]: 108Platter weight [kg]: 18Platter material: derlin and cast ironMaterial: aluminium,copper,inox,brown,cast ironBearing type: ceramic ball-invertedMotor [pcs]: 4 DCBelt: rubberRotation speed [rpm]: 33; 45No. of tonearms: 1 (+2 optional)Armboard: yesClamp: yesGlass mat: yesPower supply: yesDimensions [mm]: 560 x 560 x 380
Total weight [kg]: 80Platter weight [kg]: 18Platter material: derlin and cast ironMaterial: aluminium,brass,copper,inox,brownBearing type: ceramic ball-invertedMotor [pcs]: 2 DCBelt: rubberRotation speed [rpm]: 33; 45No. of tonearms: 1 (+1 optional)Armboard: yesClamp: yesGlass mat: yesPower supply: yesDimensions [mm]: 620 x 350 x 40
- Bearing type: unipivot
- Material: aramid fibres, aluminium, bronze, cast iron, stainless steel
- Oil damping: yes
- Tube: conical (aramid fibres)
- VTA adjustment: yes
- Azimuth: yes
- Mass: 890g (+armboard 140g)
- VTA mass: 225g
- Effective lenght: 304,8mm
- Mounting distance: 291 mm
- Effective mass: 13g
- Standard wiring: silver mono-crystal Albedo (exclusively for J.Sikora)
- Available colours: natural yellow / lacquered black mat
http://www.jsikora.pl/en/products.html
