Τελικος krell Ksa 100s
Πωλειται το θηριακη της Krell ksa 100s στα 2100e η ανταλλασεται με monoblock λαμπατους με διαφορα χρηματων απο μερος μου!
This is a Class AB AMPLIFIER which, utilize Sustained Plateau Biasing, a proprietary KRELL design.
This technique insures all signal is passed through the amplifier in pure Class A operation. Hence the sound stage is most of the time generated in pure class A.
This is one of Krell's highly famous Amp with 100W per channel at 8 Ohm speakers or 200W per channel at 4 Ohm Speakers.
Fully dual monaural balanced design handles each channel separately. This is an extra ordinary audiophile Amplifier.
It has both standard RCA and balanced XLR input. The output allows bi-wiring.
The KSA-100S, built with legendary Krell attention to construction quality and able to drive difficult loads,
is undoubtedly a highly competent amplifier. Its sonic personality is slightly on the soft yet detailed,
which usefully minimized the hardness of many digital recordings and does not give you fatigue from long time listening.
If past experience with Krell products is anything to go by, the KSA-100S is highly reliable and solid state amplifier
opanamas
