Τι λετε γιαυτο?
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Δεν ηξερα σε ποια κατηγορια να το ενταξω.
Ομως νομιζω πως ανηκει εδω.
Εντυπωση μου εκανε η συχνοτατη αναφορα απο Κεντροευρωπαικα φορα στην εν λογω συσκευη.
Το Reelbox PVR-1100 ειναι:
DVB-Receiver
Videorecorder
και DVD-Player
σε μια συσκευη.
Ομως οι τοσο συχνες αναφορες αφορουν περισσοτερο την δυνατοτητα αναπαραγωγης HDTV.
Κοστος 699€
Θα επιθυμουσα, εαν ειναι δυνατον, την γνωμη του Μιχαλη αλλα και των αλλων παιδιων που ασχολουνται στην συγκεκριμενη κατηγορια διοτι μου "μυριζει" καλο πραγμα. :)
Περισσοτερα http://www.reel-multimedia.com/de/Endkunde/Produkte.html
ReelBox PVR 1100
... the digital media centre for the best in entertainment!
The ReelBox PVR 1100 has features that seem like a dream come true: digital receiver, VCR and DVD player all in one device. These three features are combined in perfect interoperability. The product is called ReelBox PVR 1100, features excellent ease of use, high expandability and, most importantly: outstanding future-readiness. This is guaranteed by the open Linux platform, various external interfaces and Internet connectivity.
TV, radio, video, DVD, music ...
Choose from thousands of digital high-quality TV and radio channels, including encrypted channels! Record several programmes at the same time — just by pressing a button. The Electronic Programme Guide (EPG) makes it delightfully easy. DVDs, Video CDs and MP3 CDs can be played back at excellent quality.
... and this is only the beginning
The ReelBox PVR 1100 can be extended according to your requirements. Software updates, new skins and extensions can be installed from a CD, the network, a Smartcard or downloaded directly from the Internet. Hardware extensions can be added to the media centre just as easily — keyboards, mice, joysticks, portable MP3 players or Firewire hard discs are just a few examples. You can also use your PC to access the ReelBox PVR 1100 media centre! Instead of into the future you might also want to look into the past: Digitize your old analogue videos and audio cassettes!
Difficult? Not at all.
Use every feature just like that — thanks to the intuitive ReelZap interface and clear documentation! In addition, you will profit from extensions and know how provided by the competent Linux developer community.
Interested?
Please bear with us for just a little longer: The ReelBox PVR 1100 media centre will be available from your dealer in September 2004. Supplier information will be provided on this website shortly. Until then, you might want to take a look at the detailed
Μπορείτε να το δείτε εδώ:
http://www.reel-multimedia.com/en/Endkunde/PVR_1100.html ή
http://www.reel-multimedia.com/cache/datenblatt_de.pdf για όσους ξέρουν γερμανικά!
Διαβάστε και τα παρακάτω:
ReelBox PVR 1100
[PVR1100] 0.00EUR
Click to enlarge
Feature Overview
Digital TV and Radio Receiver
With the ReelBox PVR 1100 you can choose from thousands of digital TV and radio channels. Extremely fast switching makes channel hopping a pleasure. Choose from three models: PVR 1100 S (for satellite), PVR 1100 C (for cable) and PVR 1100 T (for terrestrial). You can even receive encrypted channels! The PVR 1100 S is equipped with two CI module slots and a Smartcard slot. It comes with an integrated FreeX module. The Electronic Programme Guide (EPG) allows you to view the current programme at a glance and offers detailed information about individual programmes and broadcasts. Channel lists can be edited directly on the PVR 1100, via remote control or at the PC (software for Windows and Linux). Teletext can be displayed using the integrated software decoder or via the TV set decoder. You control the programmes that your children are allowed to watch. The ReelBox PVR 1100 parental lock can be based on channels and broadcast times.
Personal Video Recorder (PVR)
The twin tuner can process two transponders at the same time. This enables you to record one program while watching another. Programmes can be paused by the press of a button — and then seamlessly resumed thanks to intelligent Reel time shifting. A recording can be started instantly, by the timer or through the EPG — usually just by pressing a button! The editing functions can be used to remove scenes from recordings or to join two separate recordings. Recordings can be stored on the hard disc (to be installed as an upgrade), on Firewire mass storage or on the network.
DVD Player
The PVR 1100 media centre is capable of high quality playback of all standard formats: DVD, Super Video CD (SVCD), Video CD (VCD), Audio CD, MP3 CD and JPEG CD. Recordable media are also supported: CD-R(W), DVD-R(W) and DVD+R(W). Audio and video can be freely combined. For example, combine your favourite MP3s with a JPEG slide show or with the visualization plugin. The CD player supports the CDDB CD database. Grab audio CDs at 3x to 5x speed.
Networking and Internet
Use the PVR 1100 media center to access shared files on your PC. Supported formats are JPEG, PNG, BMP, MPEG-1/2/4/DivX, MP2, MP3 and others. Use your PC for editing and playing your recordings. Plug a DSL modem into the Fast Ethernet port to connect the ReelBox PVR 1100 media centre directly with the Internet! While you are on the road you can control the ReelBox PVT 1100 through its web interface*, to use functions such as programming the timer for a recording. You can do this from an Internet Café, but also from a Notebook or PDA with HTML support. (* This requires a connection to the Internet.) Install software updates, new skins, themes and extensions for your ReelBox PVR 1100 media centre.
Interfaces for Digital and Analogue Devices
3 USB ports are available for keyboard, mouse and joystick (2 on front, 1 on back). Additionally, 3 ports are available for IEEE 1394 mass storage devices and MP3 players (1 on front, 2 on back). A headphone jack is accessible from the front. Digitize your precious video and audio material from your analogue video or audio cassette recorder in realtime using MPEG-1/2/4 compression or MP2 and MP3 encoding. The media centre is equipped with numerous analogue inputs and outputs: Audio (Stereo, 5.1), Video (Composite, S-Video, RGB/YUV) and two SCART connectors. The Ethernet port (100 MBits) can be used to archive the digitized audio and video material on the PC. Music from Minidisc and DAT can be encoded via the digital audio input (S/PDIF) as MP2 or MP3. The coaxial and optical S/PDIF outputs support Dolby Digital. View pictures from your digital camera — with the flashcard/microdrive reader. The HF modulator enables you to connect multiple TV sets to the PVR 1100 media centre.
Open Platform
The Linux kernel guarantees high stability and performance. The interface is based on Open Source and built in a modular fashion. This facilitates rapid development of extensions and skins for changing look and feel. The development kit is freely available. Leverage the know how of the Linux developer community: In our forum you can discuss the media centre, ask questions, suggest improvements and propose new features.
Ease of Use
Standard menus for normal users and extended expert menus ensure access to an impressive set of features while maintaing ease of use. Instead of the remote control, a standard USB keyboard and mouse can optionally be used to control the interface. The media centre can also be conrolled completely by using the buttons on the media centre itself. The 128 x 64 pixel display ensures optimal readability. Just plug in a network cable to you have complete control over the ReelBox PVR 1100 from your PC. The included software runs under both Windows and Linux.
For more information, please visit this products webpage.
This product will be in stock on Wednesday 15 September, 2004.
Gver1
