Το μικρότερο TV tuner (analog + DVB-T)
The world's most mobile TV card!
The Cinergy Hybrid T USB XS receives digital and analogue TV signals, yet is no larger than a USB memory stick! Just connect the ultra-compact TV tuner to a notebook or PC via a USB 2.0 port – and in a flash you're able to view both all analogue TV programs available in the transmission area and the digital programs transmitted via DVB-T. The Cinergy Hybrid T USB XS supports both standards in one device, and is therefore flexible and has a guaranteed future.
Regardless of where you are, your TV card is there with you. At a stationary PC at home you receive programs via the house antenna or the analogue cable connection. Away from home you simply connect the handy tuner to your notebook and use the included DVB-T compact antenna. And you don't ever have to go without the accustomed TV viewing comfort, as a matching remote control is also included.
You can also use the Cinergy Hybrid T USB XS as a digital video recorder for recording analogue and digital terrestrial TV programs with full MPEG 2 support. The electronic program guide (EPG)* helps you accurately navigate through the large number of stations and activate your recording timer. The integrated videotext function makes sure you're excellently informed even beyond the TV program.
Finished recordings can be recorded on CD or DVD with just a few mouse clicks using the included software, enabling you to build up your own film archive. And if you have to interrupt a program for some reason, the TimeShifting function saves the part you miss on the hard disk. That means you can simply resume viewing later at the desired point. The Cinergy Hybrid T USB XS is also equipped with inputs for analogue video and audio signals with which you can import analogue videos from camcorders and video recorders to your computer.
Analogue TV and DVB-T, digital video recordings, EPG, TimeShifting, Videotext, video import and CD/DVD recording – only the Cinergy Hybrid T USB XS offers so many functions in such a small device!
Τιμή : 129 ευρώ
Εταιρία : terratec
Τεχνικά χαρακτηριστικά
Features
Digital and analogue TV for notebooks and PCs
Scheduled recordings and time shifting
EPG support (DVB-T mode only)
Teletext
Power supply via USB
USB 2.0 interface (480 Mbps)
Infrared remote control
Digital video recorder with full MPEG2 support
Analogue video inputs: S-Video, Composite
Stereo audio input
General
Plug n’ Play
Voltage: 5V DC (USB bus powered)
Current: 480mA (USB bus powered)
Housing colour: white/orange
Dimensions: 80 x 30 x 15 mm
48 buttons
2 x AAA batteries
System requirements
Intel Pentium 4 / AMD Athlon XP / Centrino certified CPU/ 2 GHz or higher
512 MB RAM
1 available USB 2.0 interface
Audio hardware with DirectX support
CD-R/DVD-R-Laufwerk for creating Video-CDs/Video-DVDs
AGP graphics board with DirectDraw drivers and video overlay support
Terrestrial digital TV reception (DVB-T, TNT)
Microsoft Windows® XP with Service Pack 2
Scope of delivery
TerraTec Cinergy Hybrid T USB XS
USB2.0 extension cable (0.3m)
Antenna adaptor cable
Breakout cable video input/audio input/remote control receiver
Antenna with magnetical base
Infrared remote control incl. batteries
Installation/software CD-ROM
Manual on CD-ROM
George Tzelalis
