ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Δεν θα γραψω ποσο τον δινουν διοτι υπαρχουν και...καρδιακοι
Οσοι επιμενετε δειτε εδω
http://www.lidl.fr/fr/index.nsf/pages/c.o.oow.20050523.p.Videoprojecteur
Αντρέα ΑΥΤΟ πρέπει να είναι το επόμενο τέστ.
Σε αυτόν μόνο.........
Και κοίτα μην πέσουν τίποτα σαγόνια στο πάτωμα......
Model TARGA Projector PD-2810 W
Type Home Cinema DLP Projector
Main Features
Video Brightness: 1000 ANSI Lumen
Resolution: 854 x 480 Wide VGA
Objectiv: 1,18 x Zoom
Contrast: 1000:1
TV standard PAL / SECAM / NTSC 4.43 ; PAL M, PAL N, PAL 60, PAL/NTSC Progressiv Scan
Input Connections Video
VGA-In (D-Sub 15 pol.) RGB
Component-Video (3 x cinch)
S-Video (hosiden)
Video (cinch)
Input Connections Audio
Audio R/L (cinch)
PC Audio In (3,5 mm stereo jack)
Power Input Loudspeaker
1 x 1 Watt
Highlights
Super silent : 28dB (ECO-mode: 800 ANSI Lumen 26dB)
PC-compatibility: VGA, SVGA, XGA, SXGA
Possebilities for projektion: front-, back-, ceiling-projection
economic life-time of the lamp: 2000 hrs(ECO-mode: 3000 hrs)
Key-Stone correction: automatic, ± 15°
Lens-Shift (vertical):verzerrungsfreies Verschieben des Bildes um ½ Bildhöhe
Standard Accessory
• Remote control
• Objectiv protective cap
• Strap for protective cap
• Power cord (4,5 m)
• VGA cable (D-Sub 15pin)
• Stereo Audio Cinch cable
• Video Cinch cable
• S-Video hosiden cable
• SCART to VGA D-Sub 15pin + Stereo jack adapter
• SCART to Stereo Audio / Video Cinch Adapter
• Manual
• Serviceflyer
• carrying bag
Available Accessory Lamp: NSH 150 NEH
Power Consumption In operation: 230W; Standby: <1W; off (power switch): 0W
Power Supply 100V~- 240V~ / 50Hz
Weight 2,6 kg
Dimensions ( B x H x D in mm ) 190 x 115 x 345
Displaytyp 1x1,27 cm (0,5") DLP-Chip
Native resolution 854x480, real 16:9
Other resolutions 1.920x1.080 HDTV, 640x480, 800x600, 1.024x768, 1.280x1024, 832x624 Mac, 1.152x870 Mac
Contrast 1.200:1
Light intensity (Ansi lumens) 1.000
Keystone correction +/- 15°
Fan noise only 26 db (eco mode), whisper quiet
Special features 5 segment color wheel, lens shift, auto keystone correction, Wall color correction, 3.000 hrs. lamp live in eco mode, HDTV and PAL progessive, Off-timer, 20 languages, short throw lens, backlited remote, SCART-Video adapter, plug & play
ΑΝΔΡΕΑΣ Κ. said:Τιποτα ακομα?![]()
Χα,χα,χα........labri said:ΜΑ .............ΚΑΛΑ ΔΕΝ ΕΚΛΕΙΣΕ Ο ΚΑΜΠΑΣ;
Παλι καλα που δεν ειναι ''Tragaς''........
Το "Targa" ειναι μονο το καλυμα....
