Φταίει το HDDVD που δεν μπορούμε…
Διαβάστε και φρίξτε…
Blu-ray may have taken a commanding lead in the next-generation format war, but the group has a big problem looming: early supporters of the format will be left out in the cold when the Blu-ray Disc Association introduces BD Profile 2.0
Και τελειώνει με το πιο καλο
When BetaNews asked why these manufacturers rushed out players that were not fully capable and potentially buggy due to their BD-J implementation, the Blu-ray partner pointed blame across the room to HD DVD. "We should have waited another year to introduce Blu-ray to the public, but the format war changed the situation," he said. HD DVD was already coming and the BDA had no choice but to launch Blu-ray.
Ολοκληρο το άρθρο εδω
Απάντηση: Φταίει το HDDVD που δεν μπορούμε…
Οι ανθρωποι ειναι για γελια!
Profile 1.1 vs. Profile 2.0
Despite Profile 1.1 also being known as Final Standard Profile, there's actually still another Blu-ray specification, Profile 2.0, also known as BD-Live. The reason it's called BD-Live is that the major difference between profiles 1.1 and 2.0 is that Profile 2.0 requires that the player has an Internet connection. Although some current Blu-ray players have an Ethernet port, these are strictly for firmware updates and can't be used to access downloadable content.
Again, since Internet connectivity isn't a mandatory feature on current Blu-ray players, movie studios have not included any Internet-enabled functionality on any current Blu-ray discs to date and there are currently no Internet-enabled discs announced for the future. Internet connectivity could be used to download additional movie content, download trailers, or enable purchasing movie-related merchandise. The other requirement of Profile 2.0 is increasing the mandatory local storage capacity to 1GB, which is presumably to accommodate downloaded content.
Technical hardware requirements
Features ----------------- -- Profile 1.0 / Profile 1.1 / Profile 2.0
Required local storage ------------ None / 256 MB / 1 G
Secondary video decoder --- Optional / Mandatory / Mandatory
Secondary audio decoder --- Optional / Mandatory / Mandatory
Internet connectivity ------- Optional / Optional / Mandatory
Λογικα το ps3 μπορει να αναβαθμιστει σε profile 2.0?
Λογικά μόνο το PS3 θα μπορέσει να δουλέψει ως σοβαρός Player αυτή τη στιγμή.
Ωραία πράγματα. Τα HDDVD δεν πάνε καλά οπότε θα τα κάνουμε ανταλλακτικά, τα παλιά μας BR Players δεν θα ειναι συμβατά οπότε αυτά θα τα κανουμε μουσιακό είδος...
Matroska rulez ^_^ :-D
Ναι το PS3 μπορει να αναβαθμιστει σε 2.0
Αλλωστε στη ces παρουσιαστηκε ως BR - live συσκευη.
Και γιατί δηλαδή να είναι απαραίτητη η σύνδεση στο Internet για να δούμε μια ταινία; Μήπως ξαναγυρίζει η sony στις παλιές καλές της συνήθειες ;(βλ. rootkit)
Δε νομίζω να είναι απαραίτητο, απλά δεν θα έχεις τα επιπλέον Features σε δισκάκια που θα υποστηρίζουν το Profile 2.0
Αν και παρουσιάζουν το profile 1.1 σαν final standard και το 2.0 προσπαθούν να μας πείσουν ότι θα είναι προαιρετικό, πιστεύω ότι το τελευταίο θα είναι το τελικό. Επομένως, αν και έχω profile 1.0 player (και το PS3), το να αγοράσω ή να αγοράσει κανείς profile 1.1 το θεωρώ βλάκεία. Γιατί σε κανα χρόνο η Sony θα επαναλάβει την ίδια ιστορία: Θα απαιτήσει απο τους κατασκευαστές να τηρούν τα players τις προϋποθέσεις για prοfile 2.0. Και αφού η διαφορά του 1.0 με το 1.1 είναι το PIP commentary (θεστήκαμε δηλαδή), ενώ το 2.0 έχει πιό σοβαρά features, θα πάω κατευθείαν σε 2.0 σε μία μελλοντική αναβάθμιση. Τελικά η Sony μας έκανε χαλαρά beta testers και μ' αρέσει που και κατηγορεί το HDDVD γι' αυτό και μας λέει με λίγα λόγια, ας πρόσεχαν οι early adopters!!! Και να πώ την αλήθεια πολύ τη φοβάμαι τα μονοπώλια της Sony, γιατί δεν έχει δείξει καλά στοιχεία στο παρελθόν.
Έχετε δει τί είναι το BD-Live 2.0? Μια βλακεία και μισή... Κατεβάζεις trailers, ringtones και κάτι άκυρα παιχνίδια που παίζεις με το remote (ευτυχώς στο PS3 έχουμε τη δύναμη του Cell, χαχαχα)
Αν κάποιοι θεωρούν ότι το 1.1 με το PiP δεν είναι και καμιά τρομερή αναβάθμιση βλέποντας το BD-Live θα τους πιάσουν τα γέλια... Δεν είναι λόγος αλλαγής player σε καμία περίπτωση, με βάση όσα έχω δει το μόνο καλό του θα είναι οι εύκολες αναβαθμίσεις firmware.
Δείτε:
[YOUTUBE]LqpkmNij8io[/YOUTUBE]
Αν κάποιοι θεωρούν ότι το 1.1 με το PiP δεν είναι και καμιά τρομερή αναβάθμιση βλέποντας το BD-Live θα τους πιάσουν τα γέλια... Δεν είναι λόγος αναβάθμισης σε καμία περίπτωση, με βάση όσα έχω δει το μόνο καλό του θα είναι οι εύκολες αναβαθμίσεις firmware.
Δεν είναι σοβαρά τα ringtones??:happy_9:
Σοβαρά τώρα: Πώς ακριβώς σκοπεύουν να χωρέσουν trailers ταινιών σε 1GB χώρο που πρέπει να είναι τα BD live players??? Α κατάλαβα!!! Θα αρχίσει ο πόλεμος των Gigabytes του στύλ εγω τον έχω μεγαλύτερο!!!:happy_9: :crazy_1:
Ενα τρειλερ σε 1080p δεν καταλαμβανει πανω απο 200ΜΒ μεσο ορο. Αναλογως και την διαρκεια φυσικα. Τουλαχιστον ετσι ειναι στα τρειλερ που κατεβαζω στο ps3.
Χαχαχαχαχαα... πλακα εχουν... Ολο το σκηνικο μου κανει...
"Και τωρα που εφυγε το hd-dvd και μειναμε καπως μονοι μας... ε, μεταξυ μας, δεν ειμασταν ετοιμοι και οι αλλοι μας επαιρναν τα σωβρακα, οποτε καλα που μας επιλεξατε και σωθηκαμε..."
Re: Απάντηση: Φταίει το HDDVD που δεν μπορούμε…
να μην σου κανει το σκηνικό... ετσι είναι το σκηνικό... όπως ήταν και το PS3, όπως και τα Vista όταν πρωτοκυκλοφόρησαν όπως πολλά πράγματα, οι πελάτες πλέρωναν αδρά για να γίνουν... beta testers )(
  • loggeo
bmavroeidis
