Αφού έτσι κι αλλιώς, το μπάσο το απολαμβάνουμε κυρίως γιατί το νιώθουμε (από το......γαργαλιτό στον καναπέ μας....) και λιγότερο γιατί το ακούμε.
Από την άλλη, αν παίξουμε δυνατά κάποιο βραδυ, θα ενοχλήσουμε τους γείτονές μας.
Οπότε πιο κάτω υπάρχει μια λύση (παρόμοια με αυτήν που χρησιμοποιούν στους ΙΜΑΧ κινηματογράφους..............
Μπασοδονητές (και χωρίς να πηγαίνει το μυαλό σας στο....πονηρό!!)
ButtKicker LFE Kit
ButtKicker LFE Kit
Experience realistic special effects and concert-quality music even at low volumes
Includes amplifier and all mounting and cabling accessories
Easy to set up
Ideal for movies, music and video games
Experience realistic special effects and concert-quality music without waking the kids or disturbing the neighbors. Ideal for movies, music and gaming, the ButtKicker LFE is a "silent subwoofer" that mounts to your furniture and allows you to feel powerful bass without excessive volume. Easy to use with home theater seating, all types of furniture, or even under your floor, the easy-to-use ButtKicker LFE Kit has everything you need to connect to your home theater or video game system in minutes. No preamplifier is required. For home theater, just use the included RCA cable to go from your processor's subwoofer out to the RCA input on the ButtKicker Amplifier. Then use the included12-gauge speaker wire from the amplifier to the ButtKicker.
Buying this LFE kit saves you money. If purchased separately this kit would cost in upwards of $674.99
The ButtKicker LFE is a small, linear motor that reacts to an audio signal sent by the amplifier. It is similar to a loudspeaker, but instead of moving a cone and transferring sound waves through the air, it attaches to seats and floors and sends low frequency sound directly into the listener's body. The ButtKicker LFE utilizes a patented magnetic suspension and can be used couches, theater seating, platforms, and any type of structure. The ButtKicker accurately reproduces the "feeling" range of many natural and man-made sounds, such as earthquakes, thunderstorms, rocket launches, waves, explosions, tornadoes, volcanoes, dinosaurs, sound effects and all styles of music.
Just place the mounting plate underneath one leg of your furniture and attach the ButtKicker to the other side. Rubber isolators are included for placing under the furniture's other legs. The included amplifier is able to power one or two ButtKicker units (when wired in parallel). Does your system have wireless capabilities? The ButtKicker Wireless Package (sold separately) contains everything you'll need to enjoy your ButtKicker without running any additional wires to your furniture.
Specifications
Guitammer Product No.: BK-LFEKIT
UPC 898114000142
ButtKicker LFE
Dimensions: 5.375" H x 5.5" W, oval
Frequency Response: 5 to 200 Hz
Weight: 11 lbs. (5kg)
Nominal Impedance: 4 ohms
Power Handling: 400 watts min./1500 watts max.
Amplifier
Guitammer Product No.: BKA1000-4
Dimensions: 12" W x 11" L x 4.375" H
Weight: 25 lbs or 11.36 kg
Power Usage: 1100 Watts @ 4 ohms; 2100 Watts @ 2 ohms will power 2 ButtKicker LFEs wired in parallel or 4 ButtKickers LFEs used in individual home theater seats
High Cutoff: 40 to 160 Hz, variable
Low Cutoff: 25 Hz, switchable
Power Requirements: 115v - 230v, switchable, worldwide usage
Warranty: 2 years
A $15 heavy-item shipping fee will apply to this product.
