ερωτηση για εγγραφη bluray
hamurabi
παιδια καλησπερα. εχω ενα DTS demonstration disc to opoio ειναι 46,1GB.
Προσπαθω να το γραψω σε δισκακι σαν backup αλλα μουκαψε ηδη 3 δισκακια 50αρια.
τι να φταιει;
το αρχειο που λεει τι εγινε λεει τα εξης
1K22-1867-0795-66M4-5592-5249-****
Windows Vista 6.1
AMD64
Wow64Process
WinAspi: -
NT-SPTI used
Nero Version: 8.3.13.0
Internal Version: 8, 3, 13, 0
Recorder: <HL-DT-ST BD-RE BH10LS38>Version: 1.00 - HA 1 TA 1 - 8.3.13.0
Adapter driver: <Serial ATA> HA 1
Drive buffer : 4096kB
Bus Type : default
CD-ROM: <HL-DT-ST BD-RE BH10LS38 >Version: 1.00 - HA 1 TA 1 - 8.3.13.0
=== Scsi-Device-Map ===
=== CDRom-Device-Map ===
_NEC DV-5800E D: CdRom0
HL-DT-ST BD-RE BH10LS38 E: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
BUFE : 0
Physical memory : 4094MB (4192760kB)
Free physical memory: 1376MB (1409260kB)
Memory in use : 66 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
28.5.2013
Μεταγλώττιση UDF
6:03:52 PM #1 Text 0 File SCSIPTICommands.cpp, Line 450
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
6:03:52 PM #2 Text 0 File Isodoc.cpp, Line 6714
UDF document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
UDF Mode : pure
UDF Options : automatic
UDF Revision : 1.02
UDF Partition Type : physical
6:03:53 PM #3 Text 0 File Burncd.cpp, Line 3639
Turn on Disc-At-Once, using Blu-ray Disc media
6:03:53 PM #4 Text 0 File FilesystemSettingsValidator.cpp, Line 142
FS Settings: using validator 'CUDFSettingsValidatorBD'
ParamMode = 'automatic', changing UDF partition type from 'physical' to 'physical'
Changing UDF revision from '1.02' to '1.02'
6:03:53 PM #5 Text 0 File FilesystemSettingsValidator.cpp, Line 142
6:04:24 PM #6 Text 0 File FilesystemSettingsValidator.cpp, Line 142
6:04:26 PM #7 Text 0 File DlgWaitCD.cpp, Line 311
Last possible write address on media: 24196127 (5376:55.02, 47258MB)
Last address to be written: 24196127 (5376:55.02, 47258MB)
6:04:26 PM #8 Text 0 File DlgWaitCD.cpp, Line 323
Write in overburning mode: NO (enabled: CD)
6:04:26 PM #9 Text 0 File DlgWaitCD.cpp, Line 2946
Recorder: HL-DT-ST BD-RE BH10LS38, Media type: BD-R (seq)
6:04:26 PM #10 Text 0 File DlgWaitCD.cpp, Line 497
>>> Protocol of DlgWaitCD activities: <<<
Not enough free discspace.
(Medium in drive: BD-R DL. Medium required by compilation: BD-R/RE, BD DL.)
Data to be written: 47,258 MB (49,553,670,144 bytes)
Space available on the disc: 0 bytes (0 bytes)
6:04:26 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 754
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 24196128 (24196128) = #24196128/5376:55.3
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 24196128 blocks [E: HL-DT-ST BD-RE BH10LS38]
6:04:26 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 956
Prepare [E: HL-DT-ST BD-RE BH10LS38] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 49553670144, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|______NWA_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 24196128 | 0 | 0x00
24196128 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
6:04:26 PM #13 Text 0 File SCSIPTICommands.cpp, Line 240
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
6:04:26 PM #14 Text 0 File Burncd.cpp, Line 4430
Caching options: cache CDRom or Network-Yes, small files-No (<64KB)
6:04:26 PM #15 Phase 24 File dlgbrnst.cpp, Line 1767
Caching of files started
6:04:26 PM #16 Text 0 File Burncd.cpp, Line 4552
Cache writing successful.
6:04:26 PM #17 Phase 25 File dlgbrnst.cpp, Line 1767
Caching of files completed
6:04:26 PM #18 Phase 36 File dlgbrnst.cpp, Line 1767
Burn process started at 2x (8,990 KB/s)
6:04:26 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2673
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
6:04:26 PM #20 Text 0 File Cdrdrv.cpp, Line 10187
---- Disc Structure (BD): Disc Information on BD (00h) ----
Media Type: 1, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
--- Header ---
Disc Information Identifier: <DI>
Disc Information Format: 01 h
Number of DI Units/Aux Frames in each DI block: 8
Number of (recording) layer to which this DI Unit applies: 0
DI unit Sequence Number in DI Block: 0
Continuation flag: Next DI Unit is the start of a new set of parameters (0)
Number of DI bytes in use in this DI unit: 98
--- Body ---
Disc Type Identifier: <BDR>
Disc Size/Class/Version: 1
DI Unit Format dependent contents:
BD Structure: 34 (22 h):
2 recording layer (DL), BD-R
Hybrid Disc identifier/Channel bit length: 1 (1 h):
no DVD layer present, no CD layer present
channel bit length of 74,5 nm (25.0 GB max. per layer)
Push-Pull polarity flag bits: 00 h
Recorded mark polarity flag bits: 00 h
BCA descriptor: BCA-code present (1)
Maximum transfer rate needed by the application: 0 Mbit/s
Data zone allocation:
First Physical ADIP Address of the Data Zone of the related layer (FAA): 00020000 h (131072)
Last Physical ADIP Address of the Data Zone of the related layer (LAA): 00194E7E h (1658494)
Recording velocities:
Nominal Recording Velocity: 4.92 m/s (1EC h)
Maximum Recording Velocity: 4.92 m/s (64 h -> 100/100)=1
Minimum Recording Velocity: 4.92 m/s (64 h -> 100/100)=1
22 01 00 00 01 00 00 00 - 00 00 00 00 00 02 00 00
00 19 4E 7E 01 EC 64 64 - 46 46 46 46 3C 3C 3C 3C
00 00 00 00 AA 60 6A 05 - 05 36 1C 80 90 20 20 20
20 20 20 20 20 30 30 30 - 30 70 00 70 00 70 00 70
00 68 00 68 00 68 00 68 - 00 68 00 68 00 68 00 68
00 90 90 C0 C0 C0 00 00
--- Trailer ---
Disc Manufacturer ID: 54 44 4B 42 4C 44 h <TDKBLD>
Media Type ID: 52 46 42 <RFB>
Time Stamp [m:y]: 0 : 0000 (00 00 h)
Product Revision Number: 0
6:05:06 PM #21 SPTI -1066 File SCSIPassThrough.cpp, Line 214
CdRom1: SCSIStatus(x02) WinError(0) NeroError(-1066)
CDB Data: 0x53 00 00 00 00 01 71 34 20 00 00 00
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
Sense Area: 0x70 00 05 00 00 00 00 0A 53 00 00 D4 24
6:05:06 PM #22 Text 0 File BD.cpp, Line 539
Format BD-R with Format Type 32h, sub-type 1, spare area size 242656 -> return code 0
Allocated spare area size on disc 786432
Reserved Track size: 24196128 sect (1713420h, 47258MB) -> return code -1066
BD: Start write address at LBA 0, Recording mode: unknown Recording Mode (0),
spare area allocation: allocation (1), Stream recording: NO (0); return code -1066
6:05:06 PM #23 CDR -1066 File ThreadedTransferInterface.cpp, Line 1680
Invalid field in command
6:05:06 PM #24 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1680
Could not perform start of Disc-at-once
6:05:06 PM #25 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 83836800
6:05:06 PM #26 Phase 38 File dlgbrnst.cpp, Line 1767
Burn process failed at 2x (8,990 KB/s)
6:05:06 PM #27 Text 0 File SCSIPTICommands.cpp, Line 287
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
6:05:11 PM #28 Text 0 File Cdrdrv.cpp, Line 11450
DriveLocker: UnLockVolume completed
6:05:11 PM #29 Text 0 File SCSIPTICommands.cpp, Line 450
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
To AMD φταίει. :biggrin:
Με τι πρόγραμμα το έκανες decrypt?
gkontoletas
trouble in my brain
ξέχνα το nero και χρησιμοποίησε το imgburn
κάνε οπωσδήποτε όλα τα updates των Windows και κυρίως αναβάθμισε τους οδηγούς του storage contoller
ika
News
Απάντηση: ερωτηση για εγγραφη bluray
Εγώ μόνο με το BDBear είδα την υγειά μου στα Bluray.
hamurabi
Δεν εχω AMD:p
Οκ ευχαριστω παιδια,θα κανω ολα οσα ειπατε
Stearsa
