Καλημέρα, θέλω να σας μεταφέρω κάποιες απορίες του συγκάτοικού μου που ψάχνεται για ηχεία και θα ήθελα τη συμβούλη σας.
το σύστημά του περιλαμβάνει τα εξής:
1) τελικός: KODA KD 266B (200W/8Ω)
2)ηχεία: KODA KD123
3)μείκτης: gemini umx-7
4)cd player: pioneer cdj 100s (2)
τα χαρακτηριστικά των συσκευών φαίνονται παρακάτω"
ΗΧΕΙΑ
Model : KD-123
System Type: Two Way Two Speakers
Impedance (ohm) : 8
Frequency Response (Hz): 45 - 20K
SPL (dB): 94 ± 2
Power (W): 25 ~ 200
Driver (Tweeter + Woofer): horn + 12"
Magnet Weight (oz): 43
Al, Voics Coil (mm): Ø338
Carton Size (cm): 68 x 47 x 41.5
G.W. (kg): 21.4
ΤΕΛΙΚΟΣ ΕΝΙΣΧΥΤΗΣ
Stereo Output Power: 200w x 2 (8ohm) / 400w x 2 (4ohm)
Frequency Response: 10Hz ~ 20KHz (±11dB)
Harmonic Distortion: ³00.2% (1KHz, 120w)
Sound Channel Separation: ³557dB
Signal Input Sensitivity: £8800mv / 20Kohm
Power Source: AC220V / 50Hz
Carton Size: 58 x 56.9 x 20 cm / PC
Gross Weight: 23.5 (kg)
Item CodeKODA KD266 FEATURES: 2 stereo channels 3 phono/line convertible 1 line and 1 mic input Adjustable assing switches Channel slide curve control switch Crossfader with rotary curve control Crossfader reverse (hamster) switch State of the art cue section with split Cut feature for low , mid and high for each chanel Gain , high , mid and low tone controls for each channel Talkover Balanced and unbalanced master outputs Zone and record outputs Dual mode metering
ΜΙΚΤΗΣ
SPECIFICATIONS: Low ......... +12 dB / - 32 dB Mid .......... +12 dB / - 32 dB High...........+12 dB / - 32 dB Gain ................ 0 to -20 dB Frequency Response .. 20 Hz - 20 Khz +/- 2 dB Distortion ................0.08 % S/N Ratio .....better than 80 dB Talkover Attenuation ......-16 dB Headphone impedance .... 16 Ohm Power source .........115/18V AC 0.75A ............................230/18V AC 0.75A Dimension 10''W x 14''H x 4.33''D (254 x 335 x 110 mm ) Weight....................6.5 lbs (3kg) FEATURES: 2 stereo channels 3 phono/line convertible 1 line and 1 mic input Adjustable assing switches Channel slide curve control switch Crossfader with rotary curve control Crossfader reverse (hamster) switch State of the art cue section with split Cut feature for low , mid and high for each chanel Gain , high , mid and low tone controls for each channel Talkover Balanced and unbalanced master outputs Zone and record outputs Dual mode metering
ΑΠΟΡΙΕΣ
1)Ενδιαφέρεται να αγοράσει ηχεία.μπορείτε να του προτείνετε κάποια ώστε να τα έχει υπόψη του και να τ'ακουσει?
ακούει κατά βάση ηλεκτρονική μουσική (κατά 99.99999%, ξερά ηλεκτρονική δηλαδή
) και το δωμάτιο ειναι 5χ3μ, ενώ και ο χωρος του στην αθήνα είναι πάνω κάτω 12-15m2.
2)έχει παρουσιαστεί καποιο πρόβλημα στα monitor που τώρα διαθέτει.
συγκεκριμένα το δεξί βγάζει πολυ πιο κάλα τα πρίμα από το αριστερό στο οποίο τα πριμα ειναι σα να μην υπαρχουν.
σημείωση : τα ηχεία δεν είναι και ιδανικά τοποθετημένα.βρισκονται στις γωνίες της μικρής πλευράς του δωματίου και το αριστερό κοιτάει προς το κέντρο του δωματίου, ενώ το δεξί κοιτά προς το αριστερό ηχείο. πάντως το προβλημα με τα πρίμα υπηρχε και πριν, όταν δηλαδή τα ηχεία σχημάτιζαν ένα νοητό τριγωνο με τη θέση ακρόασης στο κέντρο του δωματίου.
τι μπορεί να συμβαίνει και τι του προτείνετε να κάνει?
3)και κάτι άσχετο. θα υπάρξει κάποιο πρόβλημα αν συνδεσω τα spendor sp2/3 (power handling 100 watt) sto παραπάνω σύστημα (200watt ο τελικος)?
ευχαριστώ
2)ηχεία: KODA KD123
ΗΧΕΙΑ
Model : KD-123
Impedance (ohm) : 8
SPL (dB): 94 ± 2
Power (W): 25 ~ 200
G.W. (kg): 21.4
ΤΕΛΙΚΟΣ ΕΝΙΣΧΥΤΗΣ
ΜΙΚΤΗΣ
ΑΠΟΡΙΕΣ
ευχαριστώ
