ο Καφατος εχει την λυση....
deleted user 10898
Upnp δικτυακη μεταδωση με καταπληκτικα αποτελεσματα.
τεραστιο FiFo buffer με διπλα ρολογια ακριβειας.
υλοποιηση με τρελλη τεχνογνωσια που καιρος ηταν να περασει και στο audio.
θελω το πρωτο δειγμα να το τεσταρο...
και το επομενο ανεξαρτητο (ψηφιακο φακο το λενε) που θα ερθει λιιγο αργοτερα σου δινω προκαταβολη απο τωρα....
(αυτος δεν δινει ντεμο ουτε στα παιδια του... θα παω εκει κανα σκ με σλιπινγκ μπαγκ...)
Απάντηση: ο Καφατος εχει την λυση....
Περίμενε να μεταφράσει ο Αργύρης, δεν κατάλανα τίποτα...
deleted user 10898
PS Audio Perfectway Bridge
The bridge is unlike anything ever built to date. Instead of a “quasi asynchronous” clocking system found in most systems we have investigated, the Bridge is a true asynchronous parallel 32 bit system approach. This means that there are actually two low jitter isolated and separate clocks (44.1kHz and 48kHz) that are completely unrelated to any other clock in the Bridge for true asynchronous performance.
There is also no digital manipulation of any kind going on in the Bridge, either through sample rate converters or DSP’s whatsoever. While many of our competitors rely on system wide clocking and digital manipulation to lower jitter and improve performance, only the PS Bridge has a real Digital Lens built into its architecture, providing low jitter I2S music without any digital manipulation and the differences are easy to hear; the PS combo is simply stunning.
deleted user 10898
http://forums.linn.co.uk/bb/showthread.php?tid=5379
I am the CEO of PS Audio and read with interest your note...
I am sure you understand that, in fact, the Lens is nothing more than a very large buffer of data (about 2 minutes worth) feeding an asynchronous clock - which outputs the data. It's an intelligent FIFO that makes decisions of how much to fill said buffer depending on what is feeding it and the needs of the fixed, asynchronous clock. Because our system depends on this type of buffer - the transport because it is using a form of EAC to RIP and the network Bridge because of streaming issues - it's a heck of a lot easier to describe what it DOES rather than how it does it - and have people get it. Our marketing may be sprinkled with hype andf market speak (BS as you term it) but our engineering and goals never are. Smile
In any case, here's to moving the high end forward! Thanks for your posting and I hope to chat again on the forum.
Paul McGowan
CEO
PS Audio
το βγαλανε επιτελους με ενα χρονο καθυστερηση....
το θεμα ειναι εαν αξιζει να αγορασεις το DAC της PS Audio που το χρησιμοποιει...
Ειχε ξεκινησει με μεγαλες φανφαρες ως το GIANT KILLER αλλα σιγα σιγα το ενδιαφερον ξεφουσκωσε.... Ειδικα οταν εβγαλε τα αντιστοιχης τιμης DAC η Naim και η Weiss....
Στα χαρτια δειχνει υπεροχο παντως...
Red
