πικάπ USB - για ευκολο transfer των βινυλίων μας!
http://www.maplin.co.uk/Module.aspx?ModuleNo=98232&source=1&DOY=12m12
USB Turntable iTT 05
Manufacturer: ION
• Transfer your vinyl collection to CD or MP3
• NEW!!! Now with integrated dust cover
• ‘Plug ‘n’ play’ USB and high-speed transfer option
• 33 and 45rpm buttons (78s are played at 33 and then converted by the software)
• Includes all cables to connect to your computer and stereo
• PC and Mac compatible
• Includes Audacity software for high-speed recording and Bias Soundsoap 2 to restore vinyl
• Belt drive turntable including a slipmat
• Requires Windows 98 SE, 2000, XP, Vista or OS9 or higher and a USB port 1.1 or higher
• Product weight: 5.5kg
• Product dimensions 50w) x 40(d) cm
The ION iTT 05 USB turnable has all the same features as our previous USB turntable but has the added benefit of an integrated dust cover, to keep dirt away from both your deck and the vinyl on it.
This innovative record deck allows you to take your vintage; and not so vintage; collection of vinyl and convert them via your PC into MP3, WAV or WMA digital files, or simply copy them to a CD. Transferring vinyl to digital has often been a complicated and expensive affair. Now you can get high quality sound transfers for an unbelievable price. The deck simply plugs into the USB port on your PC or Mac; you then either use the software to convert your music, listen to it through your computer or play it on the turntable.
If you’ve built up an enviable collection, you want to spend your days listening to them not transferring them: the Audacity software will allow you to play the records at double time to speed up the transfer process. The USB turntable is compatible with any software that supports USB audio input sound cards. All you need to do is plug it into a spare USB port; no special drivers are required.
Now there’s no excuse not to dust down those sleeves, convert the music and take a trip down memory lane.
Also available is a 78 Stylus (Order code: N90CU)
For a simple guide to recording audio using the bundled Audacity software CLICK HERE
deleted user 10898
απλο gadget για παιχνιδι μονο...
δεν πιστευω να περιμενετε μετατροπη με αυτο το πραμα...
Τα πικαπ αυτα ειναι μερικα μονο απο το πληθος των μοντελων που υπαρχουν ηδη σε κυκλοφορια.
Ωστοσο η ψηφιοποιηση των δισκων βινυλιου για οσους ηδη διαθετουν Αναλογικο πικαπ, ειναι πλεον υποθεση μιας μικρης συσκευης που διαθετει Εισοδο Phono και εξοδο USB, και περιεχει τα ιδια κυκλωματα που εχουν αυτα τα πικαπ και με χρηση του Audacity (που συνοδευει την συσκευη) κανει οτι ακριβως και αυτα.
Δηλαδη, η ιδια δουλεια γινεται με πολυ μικροτερο κοστος ( περιπου το 1/4 ) και με χρηση του υπαρχοντος πικαπ, που κατα κανονα ειναι πιο ποιοτικο απο τα παραπανω.
Επισης η συσκευη εχει και Line Εισοδο για χρηση με εξωτερικο Phono stage, ή για ψηφιοποιηση προγραμματος απο μαγνητοφωνο ή αλλη Αναλογικη πηγη με Εξοδο σε Line level.
Εχω ηδη μια τετοια μικροσυσκευη υπο εξεταση, και συντομα θα ανακοινωθουν εντυπωσεις.
Το πιθανοτερο ειναι οτι η συσκευη αυτη θα προστεθει στην γκαμα προιοντων μου.
Παντως το μονο σιγουρο ειναι οτι δεν προκειται για παιχνιδι-Gadget.
Η ΙΟΝ είναι από τις πρώτες εταιρείες που έχουν ασχοληθει με το "θέμα".
Πρόσφατα έχει μπει στο "παιχνίδι" και η Project με το Debut USB.
www.ion-audio.com
Στο λινκ θα βρείτε πολλά "παιχνιδάκια" για δώρο :)
cbk
Έχουμε κάτι νεώτερο;
Minas Notaras
