πικαπ...
2 πικαπακια σε πολυ καλη κατασταση,,,
το rotel ειναι 1ο χερι και δεν εχει γραψει ουτε 50 ωρες, πράγμα το οποιο μπορει να το διαπιστώσει κανεις..και το μονο που ζηταει ειναι ενας νεος ιμάντας
50 ευρο έκαστο
6976 108021
ευχαριστω
JVC QL-F61
Specifications
Motor: coreless DC servo motor
Drive system: direct drive
Speed detection system: integrated frequency generator
Servo system: double servo quartz
Wow and flutter: 0.025% WRMS
Signal to noise ratio: 75dB
Speed deviation: 0.002%
Platter: 0.9kg 295mm diecast aluminium
Tonearm: statically balanced arm on TH (tracing hold) system
Effective length: 220mm
Overhang: 15mm
Tracking force: 0 to 3g
Cartridge weight range: 8.5 to 12g
Operation mode: fully automatic
Dimensions: 420 x 115 x 455mm
Weight: 5.5kg
ROTEL RP1300
Specifications
Motor: 4-pole synchronous motor
Drive: belt-drive
Speeds: 33 and 45rpm
Wow and flutter: 0.08% WRMS
Signal to noise ratio: better than 55dB
Platter: 310mm, full-size, aluminium die-cast
Tonearm: static-balanced, s-shaped pipe arm, plug in headshell, oil-damped cueing device, direct-readout stylus gauge counterweight, anti-skating device
Overhang: 17mm
Cartridge weight range: 4 to 10g
Stylus force: 0.75 to 3g
Dimensions: 438 x 355 x 145mm
Weight: 5.5kg
Klipschlascala_pro1988
