τοποθετηση plasma σε τοιχο
καλησπερα παιδια υπαρχει κανενα stantart για τοποθετηση πλασμα 42αρα σε τοιχο δηλαδη αποσταση απο δαπεδο η τη βαζει οπου τον βολευει τον καθενα ρωτω για να μην κανω τον τοιχο μου σουρωτηρη καταλαβατε τρυπα βαλε την tv κατσε καναπε και συνεχεια το ιδιο πραμα οποτε διαμπερες ο τοιχος!
οποιος γνωριζει ας απαντηση μπας και γλυτωσει τον τοιχο.
ευχαριστω.
There are a number of considerations that come into play when setting the screen height. The idea is to come at a level that proves comfortable on your neck.
Ideally, the center of the screen should be at eye level when seated. Typically, this would correspond to the center of the display panel at 40-45 inches off the floor. This is the position that will result in a minimum of eye and neck movement during TV viewing.
Many may consider that aesthetically, this may yield a too low placement for a wall-mounted display. The alternative is to place the TV wall mount such that the bottom part of the screen is no higher than eye level when seated, while the top of the display is no higher that eye level when standing.
Anything in between these limits would normally lead to a comfortable viewing experience.
koskef
