το επωνυμο προιον ειναι και καλοσχεδιασμενο΄;
διαβαστετο , εχει πολυ πλακα!!!!
λυπαμαι πολυ αυτους που τα εχουν χωσει!!!!!!!!
[και να φανταστει κανεις οτι τον Γαλλο τον γουσταρω!!] ασχετα αν σε οριτζιναλ σχεδια που εχω στα χερια μου εχω δει του κοσμου τα λαθη!!!
http://www.turneraudio.com.au/Jadis-300B-reformed.html
Ημίθεος
Απάντηση: το επωνυμο προιον ειναι και καλοσχεδιασμενο΄;
Είσαι ισοπεδωτικός ρε! Ακούς εκεί... :biggrin:
ειδες τι εχει κανει; ΔΕΝ ΥΠΑΡΧΕΙ ΛΕΜΕ!!!!!!!!!!τι να πρωτο σχολιασω!!! ο εξοδου χωρις διακενο[set] ; στην τροφοδοσια;
κοστιζει και 12000 δολαρια;
ειδες τι εχει κανει; ΔΕΝ ΥΠΑΡΧΕΙ ΛΕΜΕ!!!!!!!!!!τι να πρωτο σχολιασω!!! ο εξοδου χωρις διακενο[set] ; στην τροφοδοσια; κοστιζει και 12000 δολαρια;
΄΄Tέλειος΄΄ γιά να οδηγεί περιφερειακά ηχεία πάγκου εργασίας με αποκοπή περί τα 250 Hz...:unsure:
Η δε αποστροφή του επιλόγου έχει ιδιαίτερο ενδιαφέρον:
"...The owner is now very happy with my work. He was using Atma-Sphere OTL amps with their
supposed gloriously transparent sound, and "fabulous reliability", ( Never mind so many are
parked due to repeated bias failures.) Well, after a few nights with my reformed amps,
he has sold his Atmas-Sphere amps. Hey hey, another myth just hit the dirt !!!!
Do you realize what some audiophiles say to each other? Well, one guy tells another
some of the OP tubes in an Atma-Sphere can be removed if there is too much volume
because the amp is too sensitive, or in fact the source level is way too high so gain control
works near the bottom of its range. Less OP tubes means less volume, no? makes sense, yes?
Well no, because all tubes in all OTL are working under duress and in class B and they
overheat with alarming regularity. Using less tubes mean even lower levels of sound
cause remaining tubes to cook to death. Less tubes don't give less volume because levels
in OTL amps are subject to large amounts of loop NFB, so fewer horses are flogged
harder to maintain speed.
Well guy listening thinks, ah, I can remove one 300B to make it quieter. Hmm, turns out guy
has a Wadia CD player with incomprehensible manual instructions for its digital attenuator,
which probably sounds no better than a good 20k log pot, or a DACT switched attenuator,
all despite the Wadia sales BS.
I had to insist that the guy never ever remove any OP tubes in any amp at any time ever
lest he enjoy another huge repair bill and bad sound."
και εδω το κορυφαιο κυκλωμα προστασιας , μετα το τιουνιαρισαμα !! γιατι απο την μαμα του δεν ειναι καν ενισχυτης!!!
Κατα τη γνωμη σου ποιο ειναι το καυστικο που λεει΄;:smile:
Καυστικά οξέα, πανταχόθεν...
supposed gloriously transparent sound, and "fabulous reliability",( Never mind so many are
Πάντως, τέτοια που συμβαίνουν στο χαϊφαϊ, είναι να απορείς που ανεβαίνουν οι ψηφιακές μοντούλες ; και παίζουν, κ έχει το κεφαλάκι του ήσυχο ο κοσμάκης. Ενώ με τις λάμπες, άμα δεν έχεις πιεί το καλάι με το κουτάλι στον πάγκο, δε μπορείς να είσαι σίγουρος. Leap of faith η αγορά ενισχυτή... : |
Y
Yiannis_B
Πsolid engineering @ it's best. :rolleyes:
Drizzt
