χωρις λογια
ενα απο τα πιο δυνατα ηχεια που ανεβαινει στους 40 με μια χαοτικη κορνα τιτανιου
ειναι χωρίς λόγια. αν κατάλαβες, κατάλαβες. αλλιώς να πας για ύπνο!
Nick Arvanitakis
Audio Pro
ηχειακι για home cinema
[FONT=Verdana, Arial, Helvetica, sans-serif]
JBL CATEGORIES & SERIES​
[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]JBL CATEGORIES & SERIES[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]PRODUCT SEARCH[/FONT]​
[FONT=Verdana, Arial, Helvetica, sans-serif]WHERE TO BUY[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]BUILD A SYSTEM[/FONT]​
[FONT=Verdana, Arial, Helvetica, sans-serif]MY WISHLIST[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]PRODUCT REGISTRATION[/FONT]​
[FONT=Verdana, Arial, Helvetica, sans-serif]HISTORY[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]TECHNOLOGY[/FONT]​
High End
Array Series1400 ARRAY BG
3-Way, 14" (350mm) Floorstanding Speaker [FONT=Arial, Helvetica, sans-serif]Aquaplas-treated aluminum high-frequency and titanium ultrahigh-frequency compression drivers in a freestanding SonoGlass™ horn, for screening-room quality home-theater sound. [/FONT]
EA
OTHER VIEWS:
SPECIFICATIONS
GeneralUltrahigh-Frequency Driver045Ti 1" Pure-titanium compression driver with aluminum edge-wound voice coil and 2" neodymium motor assembly, mounted in a SonoGlass™ constant-directivity hornHigh-Frequency Transducer435AL-1 3" Aquaplas-treated aluminum-dome compression driver with aluminum edge-wound voice coil and neodymium motor assembly, mounted in a vertical SonoGlass™ constant-directivity hornLow-Frequency TransducerLE14H-3 14" Aquaplas-treated pulp-cone driver with rubber surround and massive ferrite motor assembly with 4" copper edge-wound voice coil, mounted in a trapezoidal enclosureSensitivity (2.83V/1m)89dBFrequency Response (-3dB)32Hz – 40kHzMaximum Recommended Amplifier Power300 WattsCrossover Frequencies750Hz, 8kHzNominal Impedance8 OhmsPort4" FlaredDimensions (H x W x D)46-1/2" x 15-1/2" x 19" (1181mm x 394mm x 483mm)Weight per Speaker115 lb (52kg)
δες λιγο και το center
[/FONT]
High End
Array Series880 ARRAY BG
3-Way, Dual 8" (200mm) Center Channel Speaker [FONT=Arial, Helvetica, sans-serif]Designed to deliver the same timbral and phase behavior as the Project Array towers, an essential characteristic for the center channel in a multichannel system. [/FONT]
EA
OTHER VIEWS:
SPECIFICATIONS
GeneralUltrahigh-Frequency Driver045Ti 1" Pure-titanium compression driver with aluminum edge-wound voice coil and 2" neodymium motor assembly, mounted in a SonoGlass™ constant-directivity hornHigh-Frequency Transducer435AL-1 3" Aquaplas-treated aluminum-dome compression driver with aluminum edge-wound voice coil and neodymium motor assembly, mounted in a vertical SonoGlass™ constant-directivity hornLow-Frequency TransducersDual Array 8C 8" polymer-treated pulp-cone driver with rubber surround and massive ferrite motor assembly with 4" copper edge-wound voice coil, mounted in a trapezoidal enclosureSensitivity (2.83V/1m)90dBFrequency Response (-3dB)70Hz – 40kHzMaximum Recommended Amplifier Power200 WattsCrossover Frequencies1000Hz, 8kHzNominal Impedance8 OhmsPortN/ADimensions (H x W x D)12-1/4" x 28-3/4" x 11" (311mm x 730mm x 279mm)Weight per Speaker46 lb (21kg)
ou yes αλλα η b&w ακομα δεν εχει στησει ηχειακι με προδιαγραφη τσουξ σε κανενα σινεμα. Οταν το κανει το ξαναβλεπουμε ,α για claster ουτε συζητηση οι αγγλοι ειναι μονο για σπιτι αντε και κανα στουντιο .ως εκει σε επαγγελματικο ηχο νιαου
by the way οταν η jbl εφτιαχνε ηχεια οι αγγλοι αλλαζανε γευση στο τσαι
... Άσε δηλαδή που φτάνει μόνο μέχρι 40KHz, και το μόνο που κάνει, είναι να διώχνει τα κουνούπια, τις κατσαρίδες και τα ποντίκια. Να έπιανε μέχρι 45KHz, να έδιωχνε και τους τυφλοπόντικες... Αλλά και πάλι υπερτιμημένο θα ήταν. Με ένα κουνουποδιώχτη από το ηλεκτρονικάδικο της γειτονιάς, ξεμπερδεύεις, και σου μένουν και ρέστα για τσιγάρα.
σωστος και την ποντικοπαγιδα την φτιαχνεις απο το νοβοπαν απο τα b&w
Κώστας Φ.
Απάντηση: Re: χωρις λογια
Όπως λέμε "όταν εμείς οι Έλληνες γράφαμε αριστουργήματα/φιλοσοφούσαμε/είχαμε δημοκρατία κλπ οι υπόλοιποι ήταν στις σπηλιές" ή, με άλλα λόγια, "παρηγοριά στον άρρωστο".
και τωρα που βγηκαν οι αλλοι απο τις σπηλιες μπηκαμε εμεις
αχ ευρωπη εσυ μας μαρανες εσυ μας μαρανες
τζιμης πανουσης
δεν μπορω δεν μπορω με ουισκι και με σουβλακια
Ναι ρε μαμωτο και δεν μας εδωσαν ουτε ενα ''φως πολιτισμου'' να βλεπουμε μεσα στη σπηλια. Και αυτο το δωσαμε στους ξενους και δεν κρατησαμε ουτε φλογιτσα για εμας! :cool_4:
DAMBO
