2hz...100000hz
This Sati amp is build around the newly designed transformer based volume control. This design surpasses all other circuit of similar design. It has huge band-width extending from 2 hz to 100000 hz. Yet the impedance remains constant regardless of the power loading from the tube from zero to the highest output. Because of this supreme linearity, the sound will always remain linear, balanced and control regardless of the volume level.
The heart of the volume control is made by extremely high permeable nano-crystaline core based transformer. It has super fast rise time and decay. The extreme low bass performance (such as organ) can be faultlessly revealed with ease due to highest available induction from the windings of the nano-crystalline core of the super transformers. The output transformer is developed from the same technology as the volume control with nano-crystalline core, surpassing any other transformer design whether it is made by EI, double C, and Nickel Brick etc.
Another great design is that the heart of the supply. We use choke input that is free from distortion made by silicon rectifier and transistor based regulated heater supply. Likewise, the power supply to the anode is also done by choke input for the highest fidelity. This is a costly design but it matters because this section will affect the timbre of musical instrument and vocals.
The choice of a stereo configuration based design surpasses mono amp design in terms of holo-graphical presentation of the sound because the unit shares the same power source. There will be no swing of power supply in real time. It has TRUE timing of rhythm.
The total lack of transistors in the design is a guarantee for non-glaring sound. The darker side of the timbre of music can be revealed in the most natural contrast. The SATI 520 sigma is on the edge of what is possible in the design of a tube amplifier design in the category of “State of the Art.”
deleted user 10898
ο συνδυασμος πυρηνα nanochrystilline με μετασχηματιστες ειναι οτι καλυτερο σε παθητικο εχω ακουσει.
ετσι δουλευει αφτο?
NIK DRAGON
