3 προτάσεις από την Arsenal Audio
xfader
Δύο ισοσταθμιστές και ένας προενισχυτής μικροφώνου από την Arsenal Audio.
V 14
4 Band VPR 500 Format Equalizer
The Arsenal V14 is an extremely high quality,; single channel 4-Band Equalizer designed for the popular API VPR500 Rack format.
The eq features continuously variable adjustment of frequency and gain on dual concentric pots, with an eq in/out switch.
R 24
2 Channel 4 Band EQ
The Arsenal R24 Dual Channel, 4-band equalizer, features two identical channels of equalization in a rack mounted unit with internal power supply. The eq features continuously variable adjustment of frequency and gain using individual controls.
R 20
2 Channel Mic Pre
The Arsenal R20 is a dual channel, high quality microphone preamp, designed from the ground up by API's design team to offer a versatile high quality input for microphones as well as instruments.
Each channel features both a mic and an instrument input, with switched phantom power, phase, and pad. Metering is traditional analog VU.
ztv
