AAXA M2 XGA Microportable Projector Review
[imgl]http://www.projectorcentral.com/img.cfm?pid=6028[/imgl]The AAXA M2 is a light, bright, highly portable XGA presentation projector that fills the gap between full-sized XGA projectors and tiny picos. Its 110 ANSI lumens put it in the perfect niche for the display of Powerpoint presentations and other simple documents to small groups. An LED lamp keeps you going without the hassles of maintenance. The projector's one-pound weight will please anyone who travels frequently, and its onboard media player keeps the required accessories to a minimum. If you've considered pico projectors but found them not quite bright enough, the AAXA M2 might be a perfect fit. At street prices under $400, it's a solid value.
Source: projectorcentral.com
Gianni Tab
