ACOUSTIC ENERGY AE-109
Ev 8848
Προς πώληση τά πολυβραβευμένα καταπληκτικά ηχεία. Specifications: Enclosure type: 2.5-way with twin front ports, bass reflex box, Precision engineered low resonance triple chamber bass reflex enclosure,18mm MDF throughout with full internal bracing, mass loading and base plinth. Drivers : HF unit: 25mm soft fabric dome, ferrofluid cooled and damped, magnetically shielded MF/LF units: 90mm polymer-pulp diaphragm cones with 32mm high-power voice coils. Magnetically shielded. Crossover: 3-way, 8 element 12dB per octave slope at 300Hz and 3kHz with high power low-distortion toroid inductor for bass. Power Handling : 150 watts max. Overall frequency response : 35Hz to 22kHz. Frequency Response : 55Hz to 18kHz [± 3db]. Sensitivity : 90 dB/1w/1m. Impedance : 6 ohms nominal Terminals : gold-plated 2-way binding posts bi-wired. Finish : Black ash vinyl, black grille cloth. Dimensions [H x W x D]: 840 x 180 x 250mm. Weight : ~ 20kg each, 22kg each packed.
Τιμή πώλησης 230 ευρώ.
Για άμεση επικοινωνία τηλ 6974273622
Σας ευχαριστώ πολύ!
v.angelos
