Acoustic System Resonators...
Gebreselassie
Μαύρος!
The Resonance Response of an audio system is always a major factor in its musicality. The most musically neutral systems will have their resonance's spread out evenly with no clumps or gaps in their distribution...just as the best listening rooms have an even distribution of standing waves. An even distribution of resonance's establishes a level playing field for all of music's notes and overtones, allows the proper harmonic balance of the music to be preserved, and maximizes listening enjoyment.
Basic is an alloy of copper and silver and is designed for low-frequency room resonance. It weighs 4.5 grams and Tchang says it produces a straight and fast resonance. Its base is soft instrument maple.
Silver is the second in the lineup and weighs 5 grams. It is an alloy of two-parts silver to one-part copper. According to Tchang this creates a sound light, open and airy in character, intended to open up soundstage width. It uses the same soft instrument maple for its base.
Gold uses an alloy of 18-carat gold, silver and copper. It weighs 7 grams and possesses a sonic character that is rich with a slight compression. It was specifically designed for big, bright rooms with low ceilings, that have lots of damping material such as sofas and drapes. A hard instrument maple base comes standard with Gold.
Special Gold employs 14-carat gold, producing a sound that's rich, brilliant with no compression says Tchang. It weighs 6.5 grams and is for a low-ceiling basement setup, though any type of room will benefit due to its no compression characteristic
http://stereotimes.com/
Άλλο ένα "μαντζούνι" :wink:
Gebreselassie
Μαύρος!
Ναι αλλά φοριέται και στο δεξί! Σαν κόσμημα :lol:
Μετά έχουμε άδικο που τα λέμε αμερικανάκια? :roll:
Τα έχετε ακούσει και τα ονομάζετε "απάτη"; Μήπως υπάρχει η παραμικρή πιθανότητα να κάνετε λάθος και τελικά αυτά τα μαραφέτια να πραγματοποιούν ότι υπόσχονται; Αναρωτιέμαι, τελικά, μήπως η εξαγωγή συμπερασμάτων δίχως να υπάρχει προσωπική εμπειρία (που κι αυτή δεν είναι τίποτα άλλο από ΠΡΟΣΩΠΙΚΗ εμπειρία, δηλαδή ακόμη μια γνώμη) όπως τουλάχιστον προκύπτει από τα γραφόμενα, δεν έχει θέση σε συζητήσεις όπου κάποιοι από εμάς προσπαθούν να βγάλουν κάποια συμπεράσματα βασισμένα σε στοιχεία κι όχι σε υποθέσεις (οι οποίες υποθέσεις αποτελούν μια από τις μεγαλύτερες μάστιγες του hi end);
Gebreselassie
Μαύρος!
Θανάση προφανώς έχεις δίκιο. Δες τι γράφει ο reviewer :
- A Platinum $1800.00! I know, I know any one paying those prices must have escaped the nut farm.
- Barring the Acoustic Resonator's exorbitant price, my experience with the them has served as a rude-awakening. Personally, I find their improvements, when Platinum, Gold and Silver is used, on par with that of an component--which somewhat justifies their cost. Therefore, I suggest strongly, that you give a set an audition especially if you've ideas of upgrading your system. for that ailing system. They’ve literally changed what I’ve come to expect from a music playback system, and I am grateful for the experience. My thoughts about using products such as these, at the risk of being considered on the lunatic fringe, has changed, and many others here and in Europe have joined me. And if I have flipped my wig, then I wish I had done it sooner, considering the outcome. Highly recommended!
Και ο ίδιος λοιπόν έχει ανάμεικτα συναισθήματα.
Τώρα από την άλλη, νομίζω ότι το να γράψει κάποιος προσωπικές απόψεις δεν είναι κακό. Προσωπικά θα πω ότι καμία υπερβολή δεν κάνει καλό, αν και στον συγκεκριμένο χώρο ζούμε γι αυτές...
Θεωρώ δεδομένο ότι πρέπει να ψαχτεί πολύ κάποιος πριν καταθέσει 1800 ευρώ για κάτι τέτοιο και ως εκ τούτου είναι λογικό να επιδέχεται καμιά φορά και "πρώιμες" κριτικές.
Πάντως το bottom line είναι αυτό που είπες, ότι δηλαδή πριν ακούσει κάποιος κάτι καλό θα είναι να μην το χαρακτηρίζει.
Άποψή μου είναι ότι αυτά τα εξευρήματα είναι υπερβολικά ακριβά για την προσφερόμενη βελτίωση που ευαγγελίζονται και κάποιοι δεν καταλαβαίνουν τις διαφορές πριν και μετά την τοποθέτησή τους.
Έπίσης εκείνα τα "λίκνα" για να αναπαύονται τα καλώδια και να μην ακουμπούν στο πάτωμα είναι υπερβολή.
Θέλουν να μας έχουν με το χέρι στην τσέπη και συνεχώς στο ψάξιμο μου φαίνεται.
Όποιος θέλει και μπορεί ας τα αγοράσει να τα δοκιμάσει και να μας πει κι εμάς.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Κι άλλες αποψεις από reviewers για τους εν λόγω resonators:
" No disrespect to Van Evers; he does what he does, and I’d be the first to admit he knows his stuff. But I wanted an easier, softer, more conventional way. Tact room correction, along with Ric Cummins’ Argent Room Lens, provided just that. As a matter of fact, here it is five years later and counting, both products remain in my system, and no white coats have come to get me. "
Ποιοί είναι αυτοί οι reviewers πρώτα απ' όλα; Που γράφουν; Έπειτα, άλλο σημαίνει η έκφραση "είναι υπερβολικά ακριβά για την προσφερόμενη βελτίωση που ευαγγελίζονται " κι άλλο "Πολύ απάτη μου μυρίζει αυτό..." έτσι δεν είναι; Αλλά και πάλι το θέμα που έθιξα και νομίζω ότι όλοι συμφωνούμε, δεν είναι η άποψη, αλλά η έκφραση της άποψης δίχως να υπάρχει προσωπική επαφή με το αντικείμενο.Το τι λέει τώρα ο κάθε ένας που τα έχει δοκιμάσει είναι μια άλλη ιστορία και λαμβάνεται καταλλήλως υπ' όψιν. Και για να μην παρεξηγούμαι θεωρώ ότι η υιοθεσία υπερβολικών θετικών σχολίων δίχως επίσης την προσωπική επαφή με το αντικείμενο είναι εξ ίσου κακό με την απαξιωτική θέση που εκφράστικε παραπάνω.
Τώρα όσο αναφορά τα σχόλια του δεύτερου reviewer θα ήθελα να προσέξετε τι συσκευές χρησιμοποιεί για να λύσει το πρόβλημα με "συμβατικό" τρόπο όπως αναφέρει (ναι η ψηφιακή διόρθωση των ανωμαλιών της απόκρισης σε ένα χώρο είναι κάτι που όλοι μας το κάνουμε, έτσι δεν είναι;) όπως και το συνολικό κόστος του TACT μαζί με τα Argent Room Lens για να δούμε τι και πως επιτυγχάνεται ενάντια σ' αυτό το τόσο εκνευριστικό πρόβλημα (για την ακουστική του δωματίου μιλάω).
corfu11
