ADVANCE ACOUSTIC X-Uni
VonKarayian
https://advance-acoustic.com/en/archives/19-x-uni
πωλείται 300€, όχι ανταλλαγές
επικοινωνία με pm.
The X-Uni is an audiophile connected source and unique. It will allow you to listen all musical source types in the best conditions.
The X-Uni can be connected very easily to your internet home network by WIFI or Ethernet. Due to its UPnP base, you may listen internet, DAB / DAB+ radios, musics stored on hard disks of your computer (MP3, WMA, AAC+, RealAudio, FLAC, PCM, WAV FLAC…) Moreover search for software updates is carried out automatically when the device is launched and connected to internet.
The X-Uni also has a CD player, a FM tuner, a Bluetooth aptX receiver, 2 Aux inputs, 1 coaxial digital input, 1 optical digital input. Also doted of AD / DA converters, you may choose whether digital or analog inputs, as all the X-UNI functions, using whether analog or digital outputs.
Components quality is « audiophile », and connections of high level precision will improve high performance through.
A generous touch screen allow a direct access to the different functions of the menu and submenu. In addition the big LED display shows the different sources used. In CD mode, the display shows the classical functions of track and time of the disc.
A special remote control allows rapid and user-friendly access to the main functions of the X-Uni.
l.koustimpis@visualacoust
