Alesis M1 320 Monitors
xfader
THE FIRST PROFESSIONAL USB MONITORING SYSTEM WITH BUILT-IN AUDIO INTERFACE!
The Alesis M1Active 320 USB-audio speaker system is the new world-class standard for USB audio playback and capture.
Alesis brings pro-grade USB speaker performance to the computer desktop. M1Active 320 USB speakers enable you to play audio from your computer and record audio coming into the speaker to your computer. Simply plug in the USB cable to your computer – No special drivers required.
M1Active 320 USB speakers are not only substantial audio monitors, but a convenient audio interface.
Simply plug in your professional audio products directly to the M1Active 320 USB - keyboards, mic pre's, guitar effects, Dj Mixers, and regular audio components such as CD and tape players can easily be connected and recorded.
Full range, superb sound quality insures that you get more accurate audio reproduction to check your mixes.
A Bass Boost switch helps emphasize bass frequencies - Great for various room situations where you want to hear more bass emphasis. The lightweight and portable design means you can put them into a handy carrying case and take them on the road.
[FONT=Verdana, Arial]Technical specifications
_USB 1.1 audio interface
_16-Bit / 44.1-48 kHz recording and playback
_Pro-grade 1/4" plugs and standard RCA jacks
_TRS Headphone output
_Two 1/4" phone jacks inputs
_Stereo 1/8" TRS mini-jack input
_Stereo RCA inputs
_1/8" TS output to passive speaker
_Switchable power supply
_Magnetically shielded for placement near TV and computer monitors
Woofer: 3” lightweight, magnetically-shielded
Tweeter: 1” silk dome
Frequency Response:58 Hz – 25 kHz
Power:10W per channel RMS
Signal-to-Noise Ratio: 88dB weighted
Digital Conversion: 16 bit delta sigma, 44.1kHz or 48kHz sampling rate
[/FONT]
Konstantinos M.
