all the power to drugs
Available colours
Speaker stands not included.
Theater 10 THX Ultra 2 "complete set"
from € 6299,00
One of the most powerful THX® Ultra 2 systems in the world
Three identical 4-way front speakers
Switchable rear speakers
Ultimate deep bass production with a 1200 watt amplifier
Optimal sound production for large home cinemas up to 150 sqm
DOWNLOADSTechnical description and user guide as PDF:
Products:0
All prices include VAT. Shipping and handling are charged separately.
Accessories shown in our pictures are not included with the products.
DESCRIPTIONTECHNICAL DATADETAILSREVIEWS
M 1000 FCR THX Ultra 2 Satellite Speaker
The development of a loudspeaker such as the M 1000 FCR was a task that any engineer would work on with utmost pleasure – whether it be day or night.
After all, who could call himself an engineer and not wish to work on a project with the single goal of developing the best-ever THX front channel speaker – using only the very best materials and componentry – when the sky is the limit in terms of costs. Even its predecessor model, the M 990, was renowned for being the only THX speaker in the world to receive a license for the 9000 cubic foot category with its outstanding dynamic performance and extremely low distortion. This successor is the central speaker in our Theater 10 system and is the main reason why this system is unparalleled in the world for having received so many positive reviews and appraisals.
The M 1000 FCR, is even more musical and contains significant improvements. This speaker is ideally suited to recording studios and listening rooms up to 150 m2 in size. The linear frequency response and extremely low distortion specifications make this speaker the world champion in its class. The M 1000 FCR is guaranteed to be absolutely neutral in reproducing any type of audio, from music to film soundtracks. The speaker design is based on the same main concepts used in all of our THX front speakers: four-way D’Appolito configuration in horizontal format for front speakers with absolutely identical response.
Technical Data M 1000 FCR THX Ultra 2 Satellite SpeakerPower handling acc. to IEC standard, long term540 WattPower handling acc. to IEC standard, short term720 WattRedommended minimum amplifier output100 WattImpedance4-8 OhmWoofer2 x 200 mm sandwich membraneBase/Midrange driver2 x 100 mm sandwich membraneTweeter2 x 25 mm textile, 1 x 19 mm titaniumEnclosure designClosedMagnetically shieldedYesCE connector panel
with goldplated plugsYesOtherCasing design: Real beech wood veneer with black dull-finish lacquer bottoms/covers or completely dull-finish lacquer black
Measures M 1000 FCR THX Ultra 2 Satellite SpeakerDimensions (W x H x D)63.00 x 43.00 x 24.50 cmWeight28.90 kg
M 1000 D THX Ultra 2 Dipole Speaker
This full-range dipole speaker – switchable to dipole, monopole or bipole mode – utilises double symmetry and contains an integrated subwoofer. A monster of a speaker, the M 1000 D THX Ultra 2 belongs in the champion’s league.
Building on the technology of the M 800 D THX Ultra 2, this speaker is also equipped with a side-firing subwoofer, which provides permanent relief for the 130 mm mid-woofer from having to handle bass duties in the range between 80 200 Hz. As a result, the dynamic range has been enlarged yet again and distortion has been reduced even further.
This opulent full-range dipole is truly a ‘no compromise’ speaker that is also suitable for audio playback in large rooms up to 150 m2 in size.
Technical Data M 1000 D THX Ultra 2 Dipole SpeakerPower handling acc. to IEC standard, long term200 WattPower handling acc. to IEC standard, short term250 WattRedommended minimum amplifier output100 WattImpedance4-8 OhmRecommended minimum amplifier output100 WattCE connector panel
Measures M 1000 D THX Ultra 2 Dipole SpeakerDimensions (W x H x D)42.00 x 47.00 x 17.50 cmWeight12.00 kg
M 12000 SW Uncle Doc THX Ultra 2 Subwoofer
This monster of a subwoofer is a testament to our goal of building the best and most powerful subwoofer on the planet.
Its performance completely redefines the term ‘bass response’ in rooms of 150 m2 or more. You will experience movie sound effects in the bass and subsonic range with such force, and not only hear but also feel music with such purity and intensity, that you will want to watch all your favourite films and listen to all your most cherished albums all over again.
The M 12000 SW THX Ultra 2 may seem a bit large at first, and you certainly won’t be able to hide it away anywhere in your living room. But once you hear the massive bass coming from this subwoofer you won’t want to hide it either! If you enjoy perfect music and film audio, then you need a competent companion who you can always rely on. Uncle Doc fits the bill.
Technical Data M 12000 SW Uncle Doc THX Ultra 2 SubwooferWoofer2 x 380 mmRMS output power700 WattMusic power output1200 WattFrequency response25-200 Hz (-3 dB / ±0,5 dB; -6 dB at 20 Hz)PhaseYesInput level controllerYesCinch preamplifier input for amplifier/receiver with subwoofer preamplifier outputYesHighlevel inputYesEnclosure designClosed and sophisticated, reflection-reducing interior casingMagnetically shieldedYesPhysical characteristicsOtherPower amplifier especially designed for Teufel in Germany
Switched automatic switch-on function
Alternative vertical or horizontal operation
Power pack with large dimensioned ring-core transformer
Measures M 12000 SW Uncle Doc THX Ultra 2 SubwooferDimensions (W x H x D)48.50 x 118.50 x 60.00 cmWeight77.80 kg
Απάντηση: all the power to drugs
εισαι και σε ηλικα επικολασιμη:142:
σε λιγες μερες βγαινει και το homecinema choice
τα εχει πρωτη παρουσιαση στην αγγλια
α περι της ηλικιας εγω δεν λεω οτι γεννηθηκα σε δισεκτο ετος
29 φλεβαρη
και να κανω γενεθλια καθε 4 χρονια:142:
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
29 φλεβαρη
Μα δεν γεννηθηκα 29 Φλεβαρη...:144:
Και οσο για το τεστ τι να περιμενεις τους Αγγλους τωρα?
Δεν θες να στα πω απο τωρα να τελειωνουμε?
Μονο που εχω το μεγαλυτερο sub:120:
βουτα στους 10 κυκλους που βουτα το δικο μου?
αι ντοντ θινκ σο
ξεπερνα κατα μια οκταβα την προδιαγραφη thx ultra
παλι τσου
εχει 1090 στην πιατσα?
οσο για τους αγγλους τα πραματα ειναι γνωστα
μολις δουν καλωδιο μπερδευουν το δικο τους ιν με των συσκευων
πισωγλεντισμος σε ολο του το μεγαλειο
intergrale
