Alpine 2006 Av Head Units
Aυτές θα είναι οι ΑV πηγές της ALPINE για το 2006.
Εξαιρώντας το IVA-D310 που βλέπετε στην αρχή, οι υπόλοιπες είναι νέες.....
Και για αλλαγή η εταιρία παρουσίασε και πηγή 2-DIN......
Δείτε αναλυτικά........
IVA-D310
DVD/CD/MP3/WMA Receiver/AV Head Units
CEA-2006 Power Rating
CEA-2006 Power Rating ([email protected] V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 16W x 4
Max Power Output: 45W x 4
Back by popular demand, the ever-powerful IVA-D310 is ready to serve as the controller hub for your entire system. A fully motorized 7" monitor makes your life easier; now it’s simple to select your source, play music, watch movies, or use navigation! Thanks to PulseTouch™, control your music simply by using your finger on the tactile display. Play DVDs, CDs, MP3, and WMA, the choice is yours. Hook up to your iPod with the Alpine KCA-420i (sold separately) or choose from Sirius and XM Satellite Radio (Subscription required) Adjust your system to ensure a perfect match to your taste with Bass Engine controls. Get operating information on the front panel display even when the monitor is closed. Start off with the IVA-D310 and expand your multi-channel solution to take full advantage of true cinematic sound in your ride. Pair it with the new NVE-N872A, and utilize the best navigation through the same display. Connect, experience, and drive with the IVA-D310 and get the most out of your ride.
FEATURES
Tuner
• MaxTune SQ Tuner
• FM Stereo Indicator
• Preset Stations (FM:12/AM:6)
• Auto Memory
• Local/DX Selection
• Preset Address Indicator
• Up/Down Seek
SAT Radio Ready
• Sirius and XM Satellite Radio Compatible
• Preset Memory, 3-Bands (18 Channels)
• QuickSearch Function
• Category Search
• Text Scroll
Ready For iPod (with KCA-420i)
• Search Mode Selection (Playlist, Artist, Album, Song Title)
• Dedicated iPod Source Selection
• Repeat One
• Shuffle (Albums, All)
CD Player
• MDAC (Multilevel 96kHz/24 Bit DAC)
• Zero data Mute (0 Bit Mute)
• Digital Servo
• Music Sensor Up/Dn
• Disc Play/Pause
• Forward/Backward
• Music Scan/Repeat
• Music Search Function
• Dolby Digital/DTS Bit Stream Output
• CD Text, CD Text Display, CD Text Scroll
• MP3 Text Information Display (ID3 Tag)
• MP3/WMA Decoder/Playback
• M.I.X. One (Folder)/All (Random Play)
• QuickSearch Function (MP3 Files)
• CD-R/CD-RW Compatibility
CD Changer Control
• Music Sensor Up/Down
• Forward/Backward
• Disc Play/Pause
• Music Scan/Repeat (One/All)
• Elapse Time Display
• T.S.M. (Title Search Memory)
• Disc Title Memory
• CD Text Display/Scroll
• Multi-CD Changer Control (with KCA-410C)
• MP3 Changer Ready (CHA-S634)
• M.I.X. One/All (Random Play One or All)
• QuickSearch™ Function with MP3 Playback Changer (CHA-S634)
Bass Engine Plus® Sound Tuning
• Subwoofer Level Adjustment
• Subwoofer Phase Control
• Bass Center Frequency
• Bass Width Adjustments
• HP/LP Analog Crossover Adjustment
• Bass Level Control
• Treble Center Frequency
• Treble Level Control Range
• 4-Channel Time Correction
• i-Personalize
• Data Download
• Bass Focus
• MediaXpander™
• Factory Preset EQ
General
• 7" Fully Motorized In-Dash Monitor
• 50W x 4 High Power Amplifier
• Rotary Encoder Volume Control
• Auto Close/Open Capability
• Black Face w/Blue illumination Buttons
• Secondary LCD Display
• 3 PreOut (2V PreOut)
• Touch Action Display
• Direct Touch DVD Menu Operation
• Ready for iPod
• Amplifier Link
• 2-Way Selectable Crossover
• Versatile Link Ready
• Steering Wheel Remote Ready
• TDS Amp and Processor Control Capabilities
• Optical Output
• Media Playback (DVD Video, DVD-VR, VCD, CD-DA, MP3/WMA)
• Built-in Dolby Digital /DTS Decoder (2-Channel Mix Down)
• Fader & Balance Controls
• S.T.M. (Source Tone Memory)
• Clock
• Detachable Trim Plate
• Anti-Theft Detachable Front Panel
• Dimmer-on Input
• Rear Camera Input
• Dedicated Navigation Input
• Navigation Audio Mix
• Power Antenna Lead
• Remote-on Lead
• Audio Interrupt In
• Wireless Remote Control Included
• Demo Function
• Audio Mute
• CD Changer Control Function
SPECIFICATIONS
FM Tuner
• Tuning Range: 87.7-107.9MHZ
• Mono Usable Sensitivity: 0.8/9.3 (µV/dBf)
• 50dB Quieting Sensitivity: 1.3/13.5 (µV/dBf)
• Alternate Channel Selectivity: 80.0 dB
• Signal-to-Noise (S/N): 80.0 dB
• Stereo Separation: 45.0 dB
• Capture Ratio: 2.0 dB
AM Tuner
• Tuning Range: 530-1, 710kHz
• Usable Sensitivity (IEC Standard): 22.5/27.0 (µV/dBf)
CD Player
• Signal-to-Noise (S/N): 105 dB
• Sampling Rate: 44.1kHz
• Horizontal Resolution: 500 Lines or Greater
• Channel Separation (1kHz): 85 dB
• Dynamic Range (1kHz): 95 dB
• Total Harmonic Distortion (THD): 0.0008%
• Frequency Response: 5-20k ±1 dB
• Number of DACs: 2
• DAC Type: MDAC (96kHz/24Bit Multi-Level DAC)
• Optical Output: Toslink (Dolby Digital/DTS/LPCM)
• Oversampling: 8X/352.8kHz
• Wow & Flutter (%WRMS): B.M.L.
Monitor
• Screen Size: 7" Widescreen
• Background Color (Selectable): Blue/Green/Gray
• Display Wide Type: 4 Modes (Wide, Zoom, Cinema, Normal)
• Effective Number of Picture Elements: 99.99% or more
• Illumination System: U-Shaped Cold Cathode Flourescent Tube
• LCD Type: Transparent type TN LCD
• Number of Picture Elements: 336,960 pcs (480 x 234 x 3)
• Operation System: TFT Active Matrix
• Subwoofer Level Adjustment Range: -15dB to 0dB (1dB Steps)
• Subwoofer Phase Control: Normal (0 or reverse 180)
• Loudness Control at 100Hz (Max): +10dB
• Bass Center Frequency : 60 Hz, 70 Hz, 80 Hz, 90Hz, 100Hz, 130Hz, 150Hz, 200Hz (Selectable)
• Bass Band Width Adjustment (Q): 4 Choices (1=Wide, 4=Narrow)
• Bass Level Control Range: ±14dB at 60Hz (2dB Steps)
• Treble Center Frequency : 10.0kHz, 12.5kHz, 15.0kHz, 17.5kHz (Selectable)
• Treble Level Control Range: ±14dB at 10kHz (2dB Steps)
• Number of Time Correction Channels: 4 Independent (FL, FR, RR, RL)
• Time Correction Adjustment Range: 0.0ms to 9.9ms (99 Steps)
• MediaXpander™ Modes: FM, CD, XM, MP3, (Level 1, 2, 3, Off), DVD Video (Level 1, 2, Off), DVD Music (Level 1, Off)
• MediaXpander™ Aux Settings : MP3, Music, Movie, (Level 1, Off)
Remote Control
• Model Number: RUE-4203
• Dimensions (W x H x D) in: 2" x 4-11/16" x 33/64"
• Dimensions (W x H x D) mm: 51mm x 119mm x 13mm
• Battery: 1 x CR2025
• Weight: 50g (1.8oz)
Dimensions
• Din Size: 1
• Chassis Size (W x H x D) mm: 178mm x 50mm x 165mm
• Chassis Size (W x H x D) in: 7" x 2" x 6-1/2"
General
• CEA-2006 Power Rating ([email protected] V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 16W x 4
• Max Power Output: 45W x 4
• Pre Output Voltage (Before Clipping): 2V
• Power Requirement: 14.4 (11-16) V.DC
• Maximum Mounting Angle: 30° from Horizontal
• Weight: 2.1kgs (4lbs 10oz)
• Black Box Weight: 1.2kg (2lbs 10oz)
IVA-D100
CEA-2006 Power Rating ([email protected] V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 18W x 4
Max Power Output: 50W x 4
The new, clean, single-DIN AV head unit steps it up with a 6.5” PulseTouch display. With PulseTouch™, you can quickly and easily find controls on Alpine's simple-to-use menus with a simple touch of your finger. Enjoy DVD Audio, DVD-MP3 playback. The IVA-D100 is an excellent addition to a complete multi-channel system for Dolby Digital® & DTS® playback. This unit is equipped with all of the pleasures as well as necessities: Full Speed™ Connection for iPod®, BlueTooth™ HD Ready, Satellite Ready, V-Link, 3 Pre-Outs, and dedicated camera input. With Quick Search™ find your music fast. The IVA-D100 is built with BBE, so it's built with maximum performance - Refine your system's sound using Bass Engine tuning. Connect, experience, and drive with the IVA-D100!
FEATURES
Tuner
• HD Radio Ready
• Auto Memory
• Up/Down Seek
HD Radio™ Ready
• HD Radio Status Indicator
• Automatic Digital/Analog Signal Switching
SAT Radio Ready
• Category Search
• Text Scroll
• Direct search function
• Repeat One
CD Player
• 24-Bit D/A Converter
• Digital Servo
• Disc Play/Pause
• Forward/Backward
DVD Player
• DVD-Audio Playback (2 Channel mix-down)
• DVD-R/DVD-RW/DVD+R/DVD+RW Compatible
• DVD-Video/DVD-VR Playback
• DTS CD Playback
• Dolby Digital Bit Stream (with 2 Channel mix-down)
• DTS Digital Bit Stream (with 2 Channel mix-down)
CD Changer Control
• Repeat (One/Disc)
• Forward/Backward
• Disc Play/Pause
Bass Engine® Sound Tuning
• Bass Center Frequency Control
• Bass Level Adjustment
• Treble Center Frequency Control
• Treble Level Adjustment
General
• 1 Aux A/V Input and 1 Aux Video Output
• 6.5" Widescreen Motorized Monitor
• Black Bird Ready (Full Compatibility)
• Full Speed Control
• Media Playback (DVD Video, DVD-Audio, DVD-VR, VCD, CD-DA, MP3/WMA)
• Black Faceplate
• PulseTouch™ Display
• Data Download
• Visual EQ
• i-Personalize
• Bass Engine
• Subwoofer Level Control
• MM Driver Ready (Hard Disc Drive Ready)
• Optical Output
• Separate Bass & Treble Control
• Loudness
• Clock
• Dimmer-on Input
• BlackOut Display
• Rear Camera Input
• Remote-on Lead
• Demo Function
• Audio Mute
SPECIFICATIONS
FM Tuner
• Tuning Range: 87.7-107.9 MHz
• Mono Usable Sensitivity: 9.3dBf (0.8µV/75 ohms)
• 50dB Quieting Sensitivity: 13.5dBf (1.3µV/75 ohms)
• Signal-to-Noise (S/N): 65.0 dB
• Stereo Separation: 35.0 dB
AM Tuner
DVD Player
• DAC Resolution: 24 Bit (Max)
• DVD Frequency Response: 5Hz-22kHz (±1dB)
• CD Frequency Response: 5Hz-20khz (±1dB)
• WOW and Flutter: B.M.L
• Total Harmonic Distortion (THD): 0.03%
• Audio Output Level: 800mV (Fixed)
• Operating Temperature: -10C to + 50C
• Power Requirement: 11-16 volts DC (Negative ground)
CD Player
• Frequency Response: 5-20k ± 1dB
• Total Harmonic Distortion (THD): 0.008% (at 1kHz)
• Number of DACs: 2
• DAC Type: 24-bit D/A Converter
• Oversampling: 8x/352.8kHz
Monitor
• Screen Size: 6.5inch Widescreen
• Number of Picture Elements: 280,800 pcs (1,200 x 234)
• Display Wide Type: 3 Modes (Wide,Cinema, Normal)
• Subwoofer Level Adjustment Range: -15dB to 0dB (1dB steps)
• Bass Band Width Adjustment (Q): 4 choices (1 =wide, 4 =narrow)
• Bass Level Control Range: +20dB to -14dB at 60Hz (2dB Steps)
• Treble Center Frequency: 7.5kHz, 10.0kHz, 12.5kHz, 15.0kHz (Selectable)
• Treble Level Control Range: "14dB at 10.0kHz (2dB Steps)
Remote Control
• Dimensions (W x H x D) in: 2" x 4-11/16" x 33/64 "
Dimensions
• Din Size: 1
• Nose Piece Size (W x H x D) mm: 169.2mm x 26.2mm x 15.7mm
• Nose Piece Size (W x H x D) in: 6-11/16" x 1-32" x 5/8"
General
• CEA-2006 Power Rating ([email protected] V =1% THD+N), S/N 80dBA (Ref: 1W into 4Ohm): 18W x 4
• Max Power Output: 50W x 4
• Operating Temperature ( °C/ °F): +32 °F to +113 °F (0 °C to +45 °C)
• Weight: (Monitor) 2.6 kg. (5 lbs. 12 oz.), (Power Amplifier) 0.47 kg. (1 lb. 1 oz.)
IVA-W200
2-DIN DVD/CD/MP3/WMA Receiver/AV Head Unit
If your car currently outfits a Double-DIN space, not to fear, the all-new, Alpine’s premier Double-DIN AV Head Unit is here! Check out the 6.5" Widescreen display for your viewing enjoyment. Control your menus using PulseTouch™ with a simple touch of your finger! Listen to and watch DVDs, DVD-MP3’s, CD’s, this unit does it all. With Quick Search™, it’s a breeze to find the music you want to listen to. Expand your multi-channel solution with the IVA-W200 and hear all of the music with higher fidelity, distinct locations, and beyond stereo. Equipped with Swingface™, this unit motorizes and closes clean and flush when not in use. Remote Control included. Thanks to BBE processing, you get improved sound quality and maximum performance. The IVA-W200 is fully enabled: Full Speed™ Connection for iPod®, HD Radio ready, Satellite Radio ready, 3 PreOuts, Bluetooth™ Ready... Alpine brings you quite possibly the best thing to happen to 2-DIN.
FEATURES
Tuner
• HD Radio Ready
• Auto Memory
• Up/Down Seek
HD Radio™ Ready
SAT Radio Ready
• Category Search
• Text Scroll
• Repeat One
CD Player
• Digital Servo
• Disc Play/Pause
• Forward/Backward
DVD Player
• DTS CD Playback
CD Changer Control
• Repeat (One/Disc)
• Forward/Backward
• Disc Play/Pause
(MMStation/Head Units) General
• 1 Aux A/V Input and 1 Aux A/V Output
• Rotary Encoder Volume Control (Pop-up Rotary Knob)
• Bluetooth® Ready
• Data Download
• Visual EQ
• i-Personalize
• Bass Engine
• Optical Output
• Loudness
• Clock
• Dimmer-on Input
• BlackOut Display
• Rear Camera Input
• Remote-on Lead
• Demo Function
• Audio Mute
SPECIFICATIONS
FM Tuner
• Mono Usable Sensitivity: 9.3dBf (0.8 μV/75 ohms)
• 50dB Quieting Sensitivity: 13.5dBf (1.3 μV/75 ohms)
AM Tuner
• Usable Sensitivity (IEC Standard): 22.5/27.0 (μV/dBf)
DVD Player
• DVD Frequency Response: 5Hz-22kHz (+-1dB)
• CD Frequency Response: 5Hz-20khz (+-1dB)
CD Player
• Number of DACs: 2
Monitor
• Bass Center Frequency : 60Hz, 80Hz, 100Hz, 120Hz
• Treble Level Control Range: +-14dB at 10.0kHz (2dB Steps)
Remote Control
Dimensions
• Din Size: 2
• Chassis Size (W x H x D) mm: 178mm x 100mm x 165mm
• Chassis Size (W x H x D) in: 7" x 3-15/16" x 6-1/2"
General
• Weight: 2.9 kg. (6 lbs. 22 oz.)
  • loggeo
opanamas
