Κώστας Φ.
Άλλο ένα Sabr-ίδιο στο παιχνίδι, το Anedio D1...
Υπερπλήρες και σε πολύ καλή τιμή ($1270.00 = 870 ευρώ με την τρέχουσα ισοτιμία).
Ασχημούλι βέβαια, αλλά δε βαριέσαι...
Kαι ένα user review από το Head-Fi.org: Click
I’ve basically just said that the $1270 Anedio D1 sounds as good as a $9000 MBL 1511E DAC paired with a $3000 Luxman P-1u headphone amp. I know that strains credibility, but I have to be honest about what I’m hearing.
I’ve been around this forum for a while and I hope that my past reviews and interactions with other members would speak to my character. I admit that it is not a completely even match. The P-1u does have a few advantages, as does the MBL if you might be using the balanced option. And of course the more expensive units look like, well, more expensive units. Whether or not that is a good thing is debatable.
What’s not debatable for me is that the D1 is an incredible value. It is up there with the absolute best and most transparent pieces of audio reproduction equipment I have ever heard. I wish I had a Berkeley Alpha DAC available to compare, as that was the last DAC I’ve heard that performed at this high of a level for a somewhat reasonable price.
