Audio Τubes (NOS)
Πωλούνται οι παρακάτω λυχνίες. Είναι NOS (αχρησιμοποίητες) αγορασμένες ως εφεδρικές.
2 τεμάχια (mached pair) 6SU7GTY Tung Sol Brownbase, clearglass (Rare To Find) 200 €
"6SU7GTY: New Old Stock Original Box. Medium glass military type, made by Tung Sol. This industrial 6SL7 has matched triode elements, and has suddenly become very difficult to find. An excellent sounding step up from standard 6SL7 tubes, well worth the search and higher cost! "
4 Τεμάχια RCA 5814A Black Plate Triple Mica 1950 (2 mached pairs) αγορασμένα από την chameleon audio. 180 € το ζευγάρι
"5814: This is a military spec tube of 12AU7. These are all low microphonic thanks to their rigid mica supports. Older versions have a third mica spacer near the top. These "triple mica" versions are in great demand today. The broadcast versions of this tube are the GE 5-star, and the RCA Command series. These vintage tubes have just started to become a hot item, as NOS stocks of the West Europe types become harder to find. These tubes can withstand many on-off cycles and mechanical shock without a problem. The RCA 5814A is more like the Mullard, with a rich warmth and wide bandwidth. "
1 τεμαχιο CV-181 David Shaw (Ceramic Base) 35 €
"http://www.iconaudio.com/shop/cv181-david-shaw/"
6 Τεμαχια JAN-CHY OD3 VR150-30 NOS Hytron USA Military issue regulator valve tubes. 20 € / τεμάχιο.
"These are from the original factory packaging and individually boxed as shown."
Επικοινωνία με ΠΜ.
20190214_152001.jpg 20190214_153854.jpg 20190214_153710.jpg DSC01448.jpg DSC01443.jpg
Νέες τιμές :
1. (2) (matched pair) 6SU7GTY Tung Sol Brownbase, clearglass 150 €
2. (4) RCA 5814A Black Plate Triple Mica 1950 (2 matched pairs) αγορασμένα από την chameleon audio. 120 € το ζευγάρι
3. (1) CV-181 David Shaw (Ceramic Base) 35 €
4. (6) JAN-CHY OD3 VR150-30 NOS Hytron USA Military issue regulator valve tubes. 15 € / τεμάχιο.
Διαθέσιμα
Δεκτή ανταλλαγή με nos E88CC (matched pair) από Telefunken / RCA / Siemens / Philips
Οι RCA 5814Α πουληθηκαν.
Διαθέσιμα :
2. (1) CV-181 David Shaw (Ceramic Base) 35 €
3. (6) JAN-CHY OD3 VR150-30 NOS Hytron USA Military issue regulator valve tubes. 15 € / τεμάχιο.
Διαθέσιμα :
Η CV-181 David Shaw πουλήθηκε
Διαθέσιμα :
2. (6) JAN-CHY OD3 VR150-30 NOS Hytron USA Military issue regulator valve tubes. 15 € / τεμάχιο.
Διαθέσιμα :
Διαθέσιμα :
Διαθέσιμα :
Διαθέσιμα :
Διαθέσιμα :
Διαθέσιμα :
Διαθέσιμα :
Δεκτή ανταλλαγή με nos E88CC, 12AX7, ECC83 (matched pair) από Telefunken / RCA / Siemens / Philips
Διαθέσιμα :
    Shalom
k.dimitriadis
