Ultra Audio
This is a filterless, non-oversampling 16 bit DAC. The main benefit from having Non-Oversampling DAC is that you simplify the whole process. Not having oversampling and filter you reduce the jitter to the minimum. The input is based on CS 8414 chip. This is a digital input interface chip widely used in all HIGH -END CD players and DAC's circuits. The digital converter is based on 8 chips TDA 1543 connected in parallel. Paralleling DAC's is the only way to reduce distortions and increase accuracy dramatically. At the output the DAC uses a Burr-Brown OPA602 op amps, paper in oil capacitors and it has separate power supplies for the digital and the analog circuits. DAC has optical and coaxial/RCA inputs. It comes with a gold plated RCA's for output. The power cord is interchangeable. This way you can use some high-end power cords with IEC320 plug to further improve the sound. We made listening tests and compared DAC with SACD. You'll be amazed how much more analog this DAC sounds compared with SACD. The detail and soundstage is amazing. Even in the low end this DAC has better resolution without loosing the detail and clarity in highs.
Resolution 16 bit
Distortions <0.018%
Output 1.5V
Dynamic range >96dB
Channel separation >90dB
Suggested MSRP: $999.00
http://www.audiomirror.com/
Resolution 16 bit
Distortions <0.018%
Output 1.5V
Dynamic range >96dB
