Τ αγόρασα από Μύθος πριν 9 μήνες περίπου (αξίας 1690Ε). Έχουν παίξει ελάχιστα λόγω αλλαγής χώρου και σχεδίων. Είναι στα κουτιά τους. Άριστη επιλογή για κάποιον που χρειάζεται κάτι για μουσική και ταινίες αλλά έχει περιορισμένο χώρο (το κάθε ένα διαθέτει ενσωματωμένο sub με ενισχυτή).
Υψηλής αισθητικής, θα λάβουν άριστα και από τη σύζυγο !
1150Ε.
Τα χαρακτηριστικά τους:
Type: Floorstanding speaker, 2-way, bass reflex with built-in 175W ace-bass subwoofer
Tweeter: 1”, soft silk dome, shielded
Midrange/woofer: 2 x 5 1/4” coated, shielded
Subwoofer: 10”, long-throw
Frequency range: 20-30.000 Hz
Impedance: 8 ohm
Crossover frequency: 100Hz/2.200Hz, 6/18dB
Lo-pass filter: 75 Hz, 24 dB/octave, electronic Linkwitz Riley filter, 4:th order
Dimensions (WxHxD): 175x1048x377 mm Foot: 210x35x382 mm
Weight: 30,5 kg/piece
Adjustments: Auto standby, separate controls for level and line-input
Connectors: Line and speaker level input, heavy duty gold plated binding post
Cabinet: MDF
Finish: High-gloss laquer foil
Colors: Black
http://www.audiopro.com/products/image-blue-diamond-v3
http://www.audioreview.com/cat/speakers/floorstanding-speakers/audio-pro/blue-diamond/prd_124313_1594crx.aspx
PS.
Posted 16 September 2011 - 05:35 PM
"Anyone know anything about Audio Pro Loudspeakers?"
Dont know anything about the SQ of those speakers but i can tell you something about the company's service.
I own a 30 year old Audio Pro sub woofer(the model that introduced the world to sub woofers).A few years ago it needed some parts.I got in contact with the company in Sweeden and they not only sent me a copy of the wiring diagram,but they also sent me the parts,FREE OF CHARGE.Not bad i reckon,and ive been in communication with them via email several times and receive almost instant replies.
1150Ε.
Impedance: 8 ohm
Cabinet: MDF
Colors: Black
PS.
