Audionet SAM Ολοκληρωμενος Ενισχυτης
Audio Harmony
Για λογαριασμο πελατη μας, ο κλασσικος multi-awarded ολοκληρωμενος ενισχυτης, Audionet SAM,
1.000 ευρω
Technical Data
Function High-End modular stereo amplifier
Power 2 x 110 Watt into 8 Ohms
2 x 200 Watt into 4 Ohms
Freq. response 0 – 500.000Hz (-3dB)
Damping factor typ. 1000 at 100Hz, (8 Ohms)
Distortion spectrum k2 typ. -100dB, k3 typ. -120dB, at 25W/4 Ohms
Noise > 112dB (A) at 10VRMS
Channel separation > 90dB for 1kHz
Input impedance 10kOhms, 150pF
Inputs 6 x LINE IN, Cinch/RCA, gold plated
Outputs 1 x REC OUT, for recorders
1 x PRE OUT, for external power amplifiers
Speakers output WBT terminals, gold plated
Headphones out 1x 6,3mm, stereo, 32..600 Ohms (rear side)
Power supply 220..240 Volts / 50..60 Hz
5W Stand-By, 700W max.
Dimensions 430mm x 110mm x 360mm (WxHxD)
Weight 16kg
Finish Front brushed aluminum, 10mm thick
(natural or black elox)
Knobs and keys Aluminum natural or black
Top brushed aluminum plates, black
Chassis 2mm steel, black
Options Massive remote control for all functions,
Phono plug-in module (MM and MC)
D/A-converter plug-in module
2 x DIGITAL IN, optional
Audio Harmony
Μπορεί να κλείσει η αγγελία. Ευχαριστούμε για τη φιλοξενία!
mrkgeo
