AVC-S7 : Ένα πολύ slimmmmm HTPC κουτί
Out of the box it's also easy to see that this isn't your average [COLOR=blue! important][FONT=Verdana, Arial, Helvetica, sans-serif][COLOR=blue! important][FONT=Verdana, Arial, Helvetica, sans-serif]computer [/FONT][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][COLOR=blue! important][FONT=Verdana, Arial, Helvetica, sans-serif]case[/FONT][/color][/FONT][/color][/color]. The case is very slim, and the dimensions are closer to those of a [COLOR=blue! important][FONT=Verdana, Arial, Helvetica, sans-serif][COLOR=blue! important][FONT=Verdana, Arial, Helvetica, sans-serif]DVD-player[/FONT][/FONT][/color][/color] than an average computer case. The front panel is simplified to the extreme and the only visible things are a power button, eject for the DVD-drive and the loading hole for the slot-loading [COLOR=blue! important][FONT=Verdana, Arial, Helvetica, sans-serif][COLOR=blue! important][FONT=Verdana, Arial, Helvetica, sans-serif]optical [/FONT][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][COLOR=blue! important][FONT=Verdana, Arial, Helvetica, sans-serif]drive[/FONT][/color][/FONT][/color][/color]. Unfortunately GMC has also included an array of symbols to the right-bottom corner. These make the case look even more like a DVD-player, but I have no idea why they are there ruining the outlooks. Besides, things like DTS and Dolby Digital-compability depend on the hardware that's inside, not the case. On a sidenote the case feels surprisingly heavy.
και ένα review:
http://www.gmc.co.kr/products/itemView_eng.php?cateID=1&itemID=4
καθώς και το site του κατασκευαστή
http://www.gmc.co.kr/index_eng.php
gvts
