ayon audio
Από την Αυστρία
ayon 300B
Specifications
Amplifier ayon 300B*
Class of Operation Single Ended
Pure Class A
Load Impedance 8 Ohms**
Negative feedback 0dB
Bandwidth 7Hz-60kHz
Output Power 2 x 20 Watt
Peak Output Power 2 x 40 Watt
Input Impedance 55K Ohm
S/N ratio 98 dB
Hum 0,003 V
Frequency Response 8 Hz - 35 kHz/ 0 dB
Frequency Response 7 Hz - 50 kHz/ -2.8 dB
Volume Control Potentiometer
Remote Control No
Inputs 3xLine, 1xDirect
Dimensions (WxDxH) cm 28x54x27 cm
Weight 31 kg
* 300B Tubes from any manufacturer may be used with this amplifier, although re-adjustment at the factory may be required.
** The amplifier's output impedance may be adjusted to 4 ohms by bridging the appropriate transformer terminals. This adjustment have to be made by an authorized ayon audio dealer or distributor.
ayon firestorm
Specifications
Amplifier ayon firestorm
Class of Operation Single Ended / Stereo Poweramp
Pure Class A
Tube Equipment 2 x 52B-S, 4x 6SN7
Power Tube Socket (3/8" x 3/8" OFC pure copper billet ) 300B custom engineered Teflon socket
Load Impedance 4 & 8 Ohms
Bandwidth 5Hz-100kHz
Output Power 2 x 30 Watt
Peak Output Power 2 x 50 Watt
S/N ratio 98 dB
Hum 0,003 V
Frequency Response 7 Hz - 50 kHz / 0 dB
Frequency Response 5 Hz - 100 kHz/ -2.5 dB
Inputs 1x RCA, 1x XLR
Dimensions (WxDxH) cm 47x39x27 cm
Weight 42 kg
Φτιάχνει και ηχεία:
ayon eagle
Specifications
Speaker ayon eagle
System 3-way
Airflow Damping
Driver Complement 1.2" Ceramic Tweeter
1 x 6.7" Ceramic Bass-Midrange Chassis
2 x 9" Ceramic Woofer
Impedance 5 Ohm
Sensitivity 93 dB
Recommended Amp Power 15 - 200 Watt
Frequency Responce 26 Hz - 35 kHz / -3 dB
SingleWire Terminal yes
Internal Wire Custommade by Shunyata Research
Dimensions (HxWxD) cm 134x45x28 cm
Weight 45 kg
ayon falcon-s
Specifications
Speaker ayon falcon-s
System 3-way
Airflow Damping
Driver Complement 1 x 1" Ceramic Tweeter
1 x 5.5" Ceramic Midrange
3 x 7" Ceramic Woofer
Impedance 5 Ohm
Sensitivity 92 dB
Recommended Amp Power 20 - 300 Watt
Frequency Responce 28 Hz - 35 kHz / -3 dB
Dimensions (HxWxD) cm 118x40x22 cm
Weight 40 kg
Our loudspeakers are designed to provide open, dynamic, lifelike sound, powerful bass, highly detailed ambient retrieval and tonal neutrality.
Combining high efficiency, linear impedance behavior and minimal phase distortion, they are equally suited for combination with single ended triode or transistor amplification. Synergistic design solutions and perfect craftsmanship make them outstanding in more than one regard.
Innovative technologies, advanced design and the best available components have been combined by our skilled designers to create loudspeakers which embody "The Next Sound Generation" in audio technology.
We offers two loudspeakers lines: high efficiency single driver designs with flow optimized cabinets and loudspeakers featuring ultimate quality ceramic drivers. Both lines employ premium internal cabling and high quality foil chokes.
Besides offering advanced technical and sonic solutions, at ayon audio we thrive for a clean, timeless design in our loudspeakers which integrates perfectly into high quality interior design concepts and domestic environments.
Nikos88
