Ayre C-5xe Universal Stereo Disc Player
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Δηλάδη ένα audio only Universal player με μόνο στερεοφωνική έξοδο!!!
Δεν υπάρχει τμήμα video, ούτε πολυκάναλη έξοδος. Ακόμα και οη ψηφιακή του έξοδος είναι στέρεο!!!
Αποκλειστικά για τον απαιτητικό audiophile!!!
Features
* Discrete decoding and playback of all formats in their native domain.
* Zero feedback, DC-coupling, true differential balanced analog circuitry.
* Twin linear power supply design.
* Exclusive Ayre DSP software.
* PCM formats are “upsampled” to quad-rate at 24 bits, and then “oversampled” to 32x at 24 bits.
* Front panel LED display indicates format selected for DVD-Audio.
* Control port allows for connection to system controller )e.g., Crestron or AMX).
Specifications
Maximum Output Level
2.05 V rms – unbalanced outputs
4.10 V rms – balanced outputs (PCM)
1.00 V rms – unbalanced outputs
2.00 V rms – balanced outputs (DSD)
Frequency Response
DC - 20 kHz (44.1 kHz sample rate)
DC - 22 kHz (48 kHz sample rate)
DC - 40 kHz (88.2 kHz sample rate)
DC - 44 kHz (96 kHz sample rate)
DC - 80 kHz (176.4 kHz sample rate)
DC - 88 kHz (192 kHz sample rate)
DC - 100 kHz (2.8224 MHz sample rate)
Output Impedance
55 ohms – unbalanced outputs
110 ohms – balanced outputs (55 per phase)
Power Consumption
60 watts maximum
Dimensions
17-¼" W x 13" D x 4-¾" H 44 cm x 33 cm x 12 cm
Weight
26 pounds 12 kg
Παναγιώτης55
