Τρία φίλτρα από την κορυφαία σειρά της B+W, σαν καινούρια, στη συσκευασία τους.
Δεν έχουν καν ίχνη σκουπίσματος.
Τα δίνω για να πάρω τα ίδια σε άλλες διαστάσεις.
1. 49mm B+W F-PRO KSM C-POL MRC (nach Kaesemann) - 60 ευρώ
http://www.schneiderkreuznach.com/e...ypes/polarizing-filters/circular-pol-auc-ksm/
https://www.schneideroptics.com/pdfs/filters/MRC.PDF
The Version for Professionals
B+W "Kaesemann" polarizers are manufactured with a polarizing foil of extremely strict and exacting specifications. In terms of color neutrality and extinction capability, the foil quality is ideal. Furthermore, the glass used for this filter is sanded and fine-polished for excellent optical quality and the advanced cementing technique prevents delamination in environments of high humidity. This filter does not impair the image sharpness of high-quality photographic lenses, which is particularly important in high-resolution digital cameras and aspherical tele lenses.
2. 72mm B+W F-PRO 007 NEUTRAL MRC - 50 ευρώ
http://www.schneiderkreuznach.com/e...tertypes/uv-and-protection-filters/007-clear/
The 007 Clear Filter meets the needs of many photographers for pure lens protection. Its sole purpose is to keep dirt, sand, and moisture off the front lens element. This extremely clear special glass with high transmittance is available with the multi-layer B+W MRC coating (Professional Line). The hydrophobic coating reduces the adhesion tendency of dirt particles and water droplets. The advantages are: extremely easy cleaning and maximum reduction of reflections.
Highly transparent protective glass
No filter effect, pure front lens protection
No multiplying factor
Made in Germany
3. 72mm B+W F-PRO KSM C-POL MRC (nach Kaesemann) + Rubber Filter Hood - 80 ευρώ
https://www.schneideroptics.com/Ecommerce/CatalogItemDetail.aspx?CID=2073&IID=5366
Made in Germany
