B&W 804S Floor-Standing Speakers
Κώστας Φ.
Specifications:
Design: 3-Way, Ported
Drivers: One 1" Aluminum
Dome Tweeter, One 6"
Midrange, Two 6.5" Woofers
MFR: 38 Hz - 22 kHz ± 3 dB
Crossover: 350 Hz, 4 kHz
Sensitivity: 90 dB/2.83
Volts/1 M
Nominal Impedance: 8 Ohms
Dimensions: 40.2" H x 9.4"
W x 13.8" D
Weight: 62 Pounds/Each
MSRP: $4,000/Pair USA
"Conclusions
B&W has produced a solid, well-built tower with exceptional attention to detail, as one would expect at this price level. The design and construction are well thought out and executed. Ample bracing, solid high quality drivers and gorgeous veneer work all combine to create one high-grade speaker. Quite an undertaking for a level entry speaker – the 804S is the entry floor-standing speaker in the 800 series.
The unique placement and construction of the tweeter fill out the top end smoothly, with no audible crossover holes. The midrange and mid-bass sections are very pleasing, providing solid bass lines and natural vocals. The only area I found lacking was the bass output, but that was in my room, and is something easily remedied with a subwoofer, of which B&W has several."
Full Review: hometheaterhifi.com
Κωνσταντίνος Παντός
