Bang & Olufsen BEOMASTER 2000 Amplifier & BeoCord 2000 Cassette Deck
Πωλείται το σετ του τίτλου στα 250€ (200€ Amp + 50€ Cassette)
To κασετόφωνο γυρνάει το καρούλι αλλά δεν παίζει. ( Όποιος έχει όρεξη να ασχολειθεί !!! )
Photos & Videos Upon Request
BeoMaster 2000 Tuner/Amplifier Type 291x Product Specifications
Model EU,FM 2911 (1983 - March 1987)
Power output RMS DIN/IEC: 2 x 30 W / 8 ohms
Harmonic distortion DIN/IEC: < 0.08 %
Power output 20 - 20,000 Hz IHF: 2 x 25 W / 8 ohms
Total harmonic distortion IHF: < 0.1 %
Dynamic headroom: 1.6 dB / 8 ohms
Intermodulation IHF: < 0.1 %
Response frequency: 20 - 20,000 Hz +/- 1.5 dB
Wideband damping factor: 35
Signal-to-noise ratio:
Phono A-weighted: > 75 dB
Tape A-weighted: > 80 dB
Power supply:
2911 - 2917: 220 V
2912 - 2915: 240 V
Power consumption 20 - 170 W
Dimensions W x H x D: 62 x 7 x 25cm
RIAA: built-in
Connections: Speakers 2 set
Phono: DIN
Tape: 1 DIN
Tape: 2 Phono
Headphone: jack
Weight 7.4 kg
BeoCord 2000 Cassette Deck (As is)
Type:
2921 (1983 - May 1987)
Compact cassette: C46-C60-C90-C120
Noise reduction system: Dolby B
Tape switch: manual ferro/chrom/metal
Wow and flutter DIN: <+/- 0.2%
Fast forward and rewind: C60 100 sec.
Frequency range chrome: 30 - 15,000 Hz +/- 3 dB
Signal-to-noise ratio: CCI/ARM
Metal Dolby B: > 56 dB TDK-MA
Chrome Dolby B: > 56 dB TDK-SA
Ferro Dolby B: > 55 dB BASF LH I
Power consumption: max 20 W
Dimensions W x H x D 42 x 7 x 24.5cm (12.5cm with lid raised)
Weight 3.8 kg
Designer: Jacob Jensen
Colours: Grey
Έχει μείνει μόνο το κασετόφωνο. Θέλει επισκευή αλλά είναι σε άψογη κατάσταση.
50€
LefterisG
