Barefoot Sound Footprint 01 & Footprint 02 Gen2
m1ts0s
News poster
"The second-generation Footprint 01 Gen2 and Footprint 02 Gen2 3-way monitors are a complete reinvention of Barefoot Sound’s acclaimed series, redesigned from the ground up to deliver greater precision, power, and transparency. While the original Footprint 01 and Footprint 02 set a high standard for compact professional monitors, the Gen2 models surpass them in every meaningful way, both technically and sonically. This next generation introduces a fully tri-amplified 3-way architecture, providing dedicated amplification for each driver to ensure optimal performance and efficiency across the frequency spectrum.
At the core of the Gen2 is Barefoot’s patented SPOC (SPectrally Optimized Conversion) Technology. This innovative system introduces analog crossover filtering before the A/D stage, allowing high frequencies to pass into the DSP unattenuated.
Barefoot’s Dual-Force technology uses opposing woofers to cancel cabinet vibrations, delivering ultra-tight bass and extended low-frequency accuracy. The result is powerful low end with stunning control and zero distortion, even at maximum output.
MEME (Multi-Emphasis Monitor Emulation) technology provides four instantly selectable monitor voicings: Flat, Hi Fi, Cube, and Old School, so engineers can reference mixes across playback environments with the push of a button, ensuring true translation every time."
Footprint 01 Gen2: $4,495.00 USD (pair)
Footprint 02 Gen2: $3,495.00 USD (pair)
https://barefootsound.com/footprint01/
https://barefootsound.com/footprint02/
173panos
