Benefits of Bi-Amping (Not Quite Magic, But Close)
Κώστας Φ.
"Most people would tend to think that bi-amping a hi-fi system (or even a sound reinforcement system) is unnecessary, or only for the most esoteric of systems. This is not the case, as the following article will attempt to demonstrate. There are very real advantages to using bi-amplification instead of the standard arrangement we commonly use, where one power amplifier must drive all the loudspeakers in the enclosure, along with the typical passive crossover network which can - at times - have a mind of its own!
If you are in a position to spend $25,000 or more for a pair of speakers, then this is approaching the 'cost no object' arena, but the majority of people cannot afford such luxuries, and must settle for something a little more pedestrian. As a result, very few systems will be as good as they can be. Biamping is not a simple tweak, and is not to be taken lightly. Make no mistake though, its application will improve almost any loudspeaker available, with very few exceptions."
Περισσότερα: Εlliott Sound Products - ESP
[Γενικώς το site έχει πολύ υλικό. Αν δεν το γνωρίζατε ήδη, ψάχτε το.]
Grigoris1966
