Benq PE-5120
Πωλειται βιντεοοπροβολεας DLP Benq PE-5120 σε αριστη κατασταση με λιγες ωρες λειτουργιας..Εκπληκτικη ποιοτητα εικονας για τα δεδομενα της κατηγοριας του.Aρχικη τιμη αγορας 900ευρω.Τιμη πωλησης 200 ευρω (Χωρις παζαρια)
Specifications. 1100 ANSI lumens, 2000:1 contrast, 854x480 native resolution, native 16:9 aspect ratio, single-chip DLP with 5-segment (red/green/blue/clear/yellow), 2x wheel rotation speed.
Compatibility. HDTV 1080i, 720p, 576p, 576i, 480p, 480i, and computer resolutions up to XGA (1024x768). NTSC, PAL, SECAM.
Lens and throw distance. Manual zoom and focus with a modest 1.2x zoom range. A 100" diagonal 16:9 image is obtained in the range of about 11.5 to 13.9 feet. There is no lens shift, but the unit has a bit more aggressive offset (projection angle) than is typical. If you ceiling mount it without tilting it downward, keeping the centerline of the lens perpendicular to the screen plane, the top edge of a 16:9 image will be located at about 1/3 the picture height below the centerline of the lens.
Lamp. 200W lamp with 2000-hour lamp life, extended to 3000 hours in eco-mode. Replacement lamp is $400 retail, which is typical for this class of product. (see article on replacement lamps).
Connection panel. Located on the rear of the unit. Video/data input connections include one DVI-I w/ HDCP, one 3-RCA component video, one S-video, and one composite video.
Απάντηση: Benq PE-5120
νεα τιμη 180ευρω.Μαζι και το βαλιτσακι μεταφορας,τηλεκοντρολ και ολα τα καλωδια μαζι με τα εγχειριδια χρησης.Δωρο 7μ καλωδιο dvi-d
711 ωρες εχει σε τελεια κατασταση ειναι..πολυ καλη ποιοτητα εικονας για την κατηγορια του
Evasound
