bg radia hyper premium set
ενα σουπερ σετ ala winsdom (ετσι για να σπαω τα νευρα του αφτια) με μοναδες αντε για.Οταν κερδισω το τζοκερ , θα χτυπησω και ενα τετοιο σετακι , να παιζουμε........http://www.hometheater.com/content/bg-radia-la-550-wall-speaker-system
γρυλοι σηκωστε καμμια εικονα να πορευομεθα...........
stathis
Ultra Home Theater
Απάντηση: bg radia hyper premium set
Specs Speaker: LA-550
Type: Two-way in-wall
Tweeter (size in inches, type): None
Midrange (size in inches, type): Neo8 wideband planar (6)
Woofer (size in inches, type): 5.25, long throw (4)
Nominal Impedance (ohms): 8
Recommended Amp Power (watts): Up to 300
Available Finishes: Black, White
Dimensions (W x H x D, inches): 7.06 x 73.25 x 3.69
Weight (pounds): 35
Price: $3,300 (back box, $169)
Speaker: SS-303
Type: Three-way in-wall
Tweeter (size in inches, type): Neo3 planar (2)
Midrange (size in inches, type):Neo10 planar (2)
Woofer (size in inches, type): 8, long throw (2)
Recommended Amp Power (watts): 50–200
Dimensions (W x H x D, inches): 32 x 11.63 x 3.75
Weight (pounds): 34
Price: $2,000 (back box, $149)
BGX-S6B Subwoofer
Enclosure Type: Sealed
Woofer (size in inches, type): 4, paper (6 per module)
Rated Power (watts): BGX-A2 Amplifier: 600 watts RMS x 2
Connections: Line-level (RCA)
Crossover Bypass: Adjustable, Fixed
Dimensions (W x H x D, inches): 14 x 14 x 3.75
Weight (pounds): 16
Price: $600 per sub module; BGX-A2 amplifier: $1,500
Company Info
BG Radia
(888) 8-PLANAR
www.bgradia.com
Spiromag
