BITTNER Tonmeister 500
Handmade high-precision transformers
Ten precisely selected and matched tube pairs
4 / 8 / 16 Ω tabs
Two analog wattmeters
Two separate high performance power supplies. One per monoblock – providing superior and uncompromising power
USB interface for diagnostics and control
Wireless control and monitoring
Remote power on with external voltages from 5 – 24 VDC
Mains supply: 230 V, 50Hz, optional 115 V, 60 Hz
Power requirement: 780 watts per channel
Two separate 9-gauge power chords with Neutrik powerCON connectors
Weight: 65 kg net, 95 kg shipping
TonMeister 500 Inputs & Outputs
Output power per channel:
250 watts continuous, 4 / 8 / 16 Ω
Frequency response:
3 Hz – 120 kHz, +0/-3 dB @ 1 watt
Rated power band:
10 Hz – 80 kHz, +0/-3 dB @ 250 watts
THD+N: 0,01 %, 1 watt @ 1 kHz
THD+N: 0,1 %, 250 watts @ 1 kHz
SNR: -114 dB (IEC-A)
Damping factor: > 15
Tubes, matched and selected:
20x KT120, 2x 6N30, 2x 6N1P, 2x 6550
TonMeister App Tablet
http://www.monoandstereo.com/2016/06/bittner-tonmeister-500-ultimate-tube.html
Αυτοι που τον φτιαχνουν υποστηρίζουν πως μπορει να σε φτασει μεχρι 7ο ουρανό με τον ηχο του δεν γραφουν τιποτα για φεγγαρι.....:D:p
v.angelos
