Bryston BP-26DA Stereo Preamplifier with Built-in DAC
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Design: Solid State, Two Channels,
Separate Power Supply
● Maximum Output: 30 Volts RMS Balanced;
15 Volts Unbalanced
● Inputs: Two Pairs XLR Analog, Six Pairs RCA
Analog, Two RCA Coaxial Digital, One Tape
Loop
● Outputs: One Pair XLR, Two Pairs RCA
● MFR: 20 Hz - 20 kHz ± 0.5 dB
● THD+N: 0.0015% at 3 Volts
● DAC: Crystal Semiconductor; One Per
Channel; 24 Bit/108 kHz Maximum Sampling
Rate
● Dimensions: 6" H x 19" W x 11" D (Both
Units Stacked Together)
● Weight: 30 Pounds Total
● MSRP: $5,095 USA as Reviewed
Για διαβαστε τι λεει:
"...The Bryston BP-26DA is a superb preamplifier. The sound is neutral, with very, very low distortion. It is a reference quality product, and an ideal choice for anyone who wants to have ultra-high-end sound in their two-channel wireless media server setup (and even if you don't have a media server . . . yet)..."
http://www.hometheaterhifi.com/volume_14_4/bryston-bp-26-preamplifier-11-2007-part-1.html
vlasis
Φωτογράφος!
Bryston B-100 SST Integrated Amplifier
Bryston has proclaimed the launch of Bryston B-100 SST included Amplifier. It features the performance levels equal to the optimum separate audio components. The amplifier segment of the B-100 SST transports 100 watts per channel into 8 Ohms and 180 watts into 4 Ohms with less than 0.02 percent from 20Hz to 20 kHz at 60 watts. The B100 SST is modern analog stereo incorporated amplifier that uses Software control for operation. B100 also offers many more features and functions while still remaining to conventional fully distinct analog circuits throughout the amplifier circuit path. B100 is obtainable at Rs. $3395 (not including remote, phono stage, or D to converter). Its full function remote is priced $430, MM phono stage $500 and internal discreet digital stage $1150.
Bryston B-100 SST Integrated Amplifier Specs:
• Three new ultra-low-noise power transformers
• Over 44,000 MFD of filter capacitance per channel
• 2 for analog circuits – 1 for digital circuits
• Computer modeled heat-sink design
• Totally separate ground paths for digital and analog sections
• Programmable pass-through feature
• Two quick-connect 12-volt triggers – (one programmable)
• Assignable digital inputs (DA version only)
• Obtainable in black or silver 17 or 19 inch faceplate
• Main-in and pre-out jacks
• New volume control
• R232 software upgradeable
• Two optical and two SPDIF inputs (DA version only)
• Optional internal D to A converter
vlasis
Φωτογράφος!
Bryston D-180Z zone amplifier
Recently Bryston has recently showcasesd its D-180Z zone amplifier at the CEDIA 2007. The D-180Z is lightweight, compact, reliable, and proves to be highly efficient zone amplifiersfor whole-house audio applications.
The characteristics of the product include Bryston engineered dual linear power supplies, all channels driven 150 watts per channel at 4 ohms, 4 stereo Zones at 180 Watts per channel into 4 ohms and 8 independent Channels at 180 watts each into 4 ohms.
Each zone is bridgeable to 400 watts all 4 zones driven into 8 ohms. The Stereo bus can be linked to other amplifiers. There is a level control on each channel and Gold plated 5-way speaker binding post that make the amplifier more profitable deal.
More additional attributes here present are that each input can select from direct input from RCA jack or left, L+R or right signals from the stereo bus and each zone can be muted independently with 12-volt trigger. It comes with 5 years of warranty.
vlasis
Φωτογράφος!
Bryston BCD-1 Hand Assembled BCD-1 Audiophile CD Player
Being situated at Peterborough, Ontario Canada Bryston has been into business since 1962 as the manufacturer of blood analysis equipment. Bryston has proclaimed the launching of an audiophile Redbook CD player called the BCD-1.
The features of the product include fully Discrete Bryston Class A analog output stage, 128 times Over-sampling, Crystal 192k/24bit DAC, Independent Analog and Digital power supplies, Transformer coupled SPDIF and AES EBU Digital outputs, Balanced XLR and Unbalanced RCA Stereo outputs, Optical output, Remote 12 Volt Trigger, RS-232 software upgrade etc.
This product also comes equipped with Full function IR remote control, cosmetically matches C-Series BP26/MPS2, CD remote operates other Bryston products volume up/down/mute etc.
It technical specification incorporate Frequency Response of 20 Hz - 20 KHz - .2 D, THD plus Noise - .002%, 115 DB (un-weighted) Signal to Noise, Output Level of 2.3V Unbalanced and 4.6V Balanced e
vlasis
Φωτογράφος!
3-1 Nα μαθεις Καφατε!!!!!!!!!!!!!!!!!!!! Σε κερδισα.....τρια-ενα
Emmanouel graecorum
