CAIRN MEA Power Amp
Mea power amplifier
Double side with metallized holes print card board s
Auto On and Auto Off s
Protection against high temperature s
Automatic temperature control by active sensor s
Gold-plated Cinch (RCA) frame inputs s
Gold-plated speaker output terminals s
Balanced input s
Unbalanced input s
0.4" (10mm) front panel in anodised aluminium s
Aluminium anti-vibration feet s
Steel Frame s
Top cover in anodised aluminium s
Solid aluminium knobs s
Stainless screws with the natural finishing s
Aluminium ventilation grid s
Black Finishing (o)
Width (mm/ inch) 216 / 8.5
Height (mm/ inch) 82 / 3.6
Depth (mm/ inch) 310 / 12.2
Weight (kg/ lbs) 10 / 16
Power supply (VA) 400
Number of toroidal transformers 2
Maximum dynamic output ( dB) 130
Output power ( RMS Watts / 8 Ohms) 100
Output power ( RMS Watts / 4 Ohms) 150
Available dynamic current ( A ) 120
Output Impedance ( Ohms) <0.05
(s) standard, (o) option.
Κωνσταντίνος Παντός
